DC JDM 4-1 install
Old Jun 14, 2003 | 05:30 PM
387's Avatar
387
Default DC JDM 4-1 install
Apexi N1 exhaust.
Carsound cat from hybrid garage.
The engine light came on after installation. (Why)?
Vibration with the exhaust. (Where)?
Rasppy sound at high rpm. (Sound like **** RICER) WTF
Old Jun 14, 2003 | 05:32 PM
NSX Bob's Avatar
New User
Default Re: DC JDM 4-1 install (387)
Check that the o2 sensors are plugged in. What is the code for the cel?
Old Jun 14, 2003 | 05:33 PM
jdmspoonitr's Avatar
That **** sounds like *** because you aren't using stock springs on any of those bolts. The rattle is probably coming from either of the following mistakes:
1. Loose 02 sensor
2. Heat shield touching exhaust
I would advise retorquing the header bolts mounted on the motor and Redoing all of the bolts under the car.
Old Jun 14, 2003 | 05:35 PM
NSX Bob's Avatar
New User
Default Re: DC JDM 4-1 install (jdmspoonitr)
You definetly need springs in the bolts between the header collector and cat. Re-use the ones that were there when you took off the stock stuff.
Old Jun 14, 2003 | 05:38 PM
387's Avatar
387
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmspoonitr &raquo;</TD></TR><TR><TD CLASS="quote">That **** sounds like *** because you aren't using stock springs on any of those bolts. The rattle is probably coming from either of the following mistakes:
1. Loose 02 sensor
I would advise retorquing the header bolts mounted on the motor and Redoing all of the bolts under the car.</TD></TR></TABLE>
O2 sensor or tight and plug in.
I know the exhaust is touching the heatshield just have to find out where.
How putting the original spring going to take away the rasppy sound?
Old Jun 14, 2003 | 05:49 PM
d8168055's Avatar
what series (model) carsound is that? the rattleing is defintetly not using the springs
Old Jun 14, 2003 | 05:54 PM
SMSP's Avatar
Default Re: DC JDM 4-1 install (d8168055)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d8168055 &raquo;</TD></TR><TR><TD CLASS="quote">what series (model) carsound is that? the rattleing is defintetly not using the springs</TD></TR></TABLE>
It's the 4" round 53006.
The flared tubing on the inlet of your cat has swallowed the donut and looks like the flare may actually touch the collector flange, so some vibration maybe coming from there. Yes, you need to reuse the stock springs for that connection.
Old Jun 14, 2003 | 06:01 PM
387's Avatar
387
54306
Old Jun 14, 2003 | 06:39 PM
asubennett's Avatar
I have a an R motor in my hatch with a JDM 4-1 and a hybrid garage cat as well. My cat bolts up in a completely different manner than yours does in the pics. The cat looks like it is swallowing up your header. YOu should be able to see a tight seal around the donut gasket. Did you you get a new S2000 donut gasket for that 2.5 collector on the JDM. If not try that. As for the rattling exhaust, try putting your silencer back in that N1 muffler. They are just loud w/o it. nothing you can do about itt. If you want a quiet exahust you shoudl have gone with greddy evo or soemthing with a muffler as opposed to a punched out coffee can. Hope this helps. If you want me to post pics of the set up I can. Later- Jason
Old Jun 14, 2003 | 06:49 PM
SMSP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 387 &raquo;</TD></TR><TR><TD CLASS="quote">
54306</TD></TR></TABLE>
The 53006 replaced the older version 54006. I never saw a 54306 p/n, but that doesn't mean it doesn't exist, it's just not in any of my catalogs for the last 3 years.
The only time I use a 2-1/2" 53006 cat is if the customer insists or they want something for the least amount of money. I use the large 93506 now. It's the one on George Knighton's 192 whp ITR with stock cams and pistons.
387's Avatar
387
Default Re: DC JDM 4-1 install (asubennett)
Use to have DC 4-1 with stock cat and N1 with silencer ( sound great nice and deep)
Now sould like like FLAT and annoying.
Yes S2000 gasket was used.
Fixed the RAT sound now have to figure out about the engine light. I hope I dont have to replace the O2 like the last time I installed my header on the gsr.
Old Jun 14, 2003 | 06:54 PM
Reid's Avatar
Global Moderator
Check the code.
If it's a code 67 (which is most likely is), don't worry about it. It's harmless.
Old Jun 14, 2003 | 07:18 PM
projecthybrid04's Avatar
Default Re: DC JDM 4-1 install (Reid)
nice pics
Old Jun 14, 2003 | 07:47 PM
Skeletor's Avatar
This maybe stupid but how can he use the spring nuts with that thing? I could barely get them sumbitches back on when I put an Autozone cat on my stock Civic DX pipe.
Old Jun 14, 2003 | 08:00 PM
d8168055's Avatar
Default Re: DC JDM 4-1 install (SMSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP &raquo;</TD></TR><TR><TD CLASS="quote">I use the large 93506 now. It's the one on George Knighton's 192 whp ITR with stock cams and pistons.</TD></TR></TABLE>And mine! (oh well, i guess im not as famous as george...)
Old Jun 14, 2003 | 08:47 PM
You just need to use the springs off the stock. For aftermarket headers, the stock bolts won't fit through the holes, but using aftermarket long bolts and the stock springs, you can get everything snug.
The raspiness is not the bolts, sorry for being unclear. The raspiness could be any number of things.
Good Luck.
Old Jun 14, 2003 | 09:23 PM
387's Avatar
387
I reset the ECM. That took care of the engine light. Now I just have to live with the whammm whamm instead of wroom wroom sound. I hope to pick up at lease 4-5hp from this for the next dyno day. My last 2 dyno day I am up with 169whp.
Old Jun 14, 2003 | 11:55 PM
sjracer's Avatar
Sup
So you actually got the JDM 4-1 header huh! Right on. Sounds like you got some problems going on. Good luck with that.
David
PS: The raspy sound sounds like it's most likely the cat you got.
Art Vandeleigh
Apr 7, 2003 10:06 AM
FJO3
Mar 17, 2003 11:50 AM
(__________)
Nov 17, 2002 03:59 PM
Smitdog
Aug 22, 2002 10:27 AM
