Diagram for fixing the "Clutch Click"
Old Jun 14, 2003 | 02:46 PM
slash00R's Avatar
New User
Default Diagram for fixing the "Clutch Click"
Before someone says to do a search, I've done it and have narrowed the clicking down to either a sticky shift fork or where the clutch pedal pushes through the firewall. Does anyone have a diagram of where to lube the shift fork? I know that worked for some people
Thanks
Old Jun 14, 2003 | 03:33 PM
JiggyKooAndy's Avatar
Default Re: Diagram for fixing the "Clutch Click" (slash00R)
what exactly is the clutch click?
Old Jun 14, 2003 | 06:22 PM
slash00R's Avatar
New User
Default Re: Diagram for fixing the "Clutch Click" (JiggyKooAndy)
When you press about a 1/4 - 1/2 down on the clutch it "pops" or "clicks" a little bit. Doesn't really affect the operation of the clutch, just is rather annoying. A few people said to put high temp lube on the shift-fork where it goes into the transmission by pulling back the rubber cover, but I can't find where that is
Besides, it sounds like the clicking noise is coming more from the footwell area so it would make more sense that it was a problem with the clutch master cylinder, but I can't find anything wrong under there. Seemingly most hondas get this eventually. My GSR had it before I got the R
Old Jun 14, 2003 | 06:29 PM
arren123's Avatar
Mine used to intermittently click until I had my clutch replaced after it broke. Pieces came off the spring retainer and one of the springs were worn down on its side.
Hopefully, you don't have the same problem.
My clutch was abused.. Sometimes I would double clutch from 5th to 3rd and didn't get the rev's right= Lots of shock to the clutch.
Old Jun 14, 2003 | 06:39 PM
Eva01's Avatar
Default Re: Diagram for fixing the "Clutch Click" (arren123)
I had a clicking noise coming from my clutch too...Here is a link on how I fixed it:
https://honda-tech.com/zerothread?id=440637
Old Jun 14, 2003 | 07:03 PM
WundedSaint's Avatar
You have to pull the transmission to lube up the fork that the throwout bearing is held by. You can try pully the slave cylinder boot off and throwing some wheel bearing grease in there, but I doubt that will solve your "clicking" noise.
Do you slam on the clutch pretty hard? Maybe the clutch master cylinder nuts got loose...try tightening those up? The firewall area is kind of thin, I guess another solution would be to get one of those braces that mount to the shock tower to keep the cylinder from moving forward.
Old Jun 14, 2003 | 08:09 PM
garagespecial
Guest
Posts: n/a
Default Re: Diagram for fixing the "Clutch Click" (WundedSaint)
its either your throw out bearing or the bearing in the middle of your flywheel...(forgot the name)
Old Jun 14, 2003 | 09:41 PM
RedlinedVTEC's Avatar
Default Re: Diagram for fixing the "Clutch Click" (garageSPECial)
I believe you mean the pilot bearing
Old Jun 19, 2003 | 08:48 AM
slash00R's Avatar
New User
Default Re: Diagram for fixing the "Clutch Click" (RedlinedVTEC)
I lubed up the slave cylinder piston thing but that didn't help. Anyone else had a problem with the clutch pedal that resulted from the spring or assembly in the footwell area?
Old Jun 19, 2003 | 08:50 AM
Larkin W.'s Avatar
Mine click right after I release the clutch after shifting. sounds like two marbles hitting each other. Bothers me a little, but its really not all that bad
Old Jun 19, 2003 | 09:48 AM
magic hat #9's Avatar
Default Re: Diagram for fixing the "Clutch Click" (EbboyPSi)
my clutch pedal squeaks/grinds and feels like i'm stepping on a pile of bugs. i lubed up the slave cylinder under the 2 boots and it seems to have helped.
Old Jun 19, 2003 | 09:51 AM
Asahi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slash00R &raquo;</TD></TR><TR><TD CLASS="quote">I lubed up the slave cylinder piston thing but that didn't help. Anyone else had a problem with the clutch pedal that resulted from the spring or assembly in the footwell area?</TD></TR></TABLE>
I have this problem. it is definitely inside the car and not a bearing or anything clutch disc related.
I ignore it or turn up the radio
Old Jun 19, 2003 | 10:52 AM
DutchITR1689's Avatar
There is also a fork bolt deeper in the fork. You should also lube that, if you can reach it....
Old Jun 27, 2003 | 09:42 AM
slash00R's Avatar
New User
Default Re: Diagram for fixing the "Clutch Click" (DutchITR1689)
Okay - just wanted to close this one out. I tried to lube up the slave cylinder rod thing but that didn't help the squeak. I finally just sprayed some WD40 on the return spring and rod that goes through the firewall (in the footwell) and the noise is completely away. The clutch motion could not be smoother now. Anyway, if you're having this problem try that first before going to the trouble of checking the master cylinder or slave cylinder.
Old Jun 27, 2003 | 01:37 PM
MK Ultra's Avatar
Sometimes when I hold my clutch open for a while (like coasting through a left turn into a parking lot or something) it "pops" about .5" off the floor coming back up. It doesn't make any noise, it just seems to catch on something on the way back up.
I'm not too worried about it, but it is kinda irritating.
Old Jun 27, 2003 | 06:51 PM
Turtle's Avatar
Default Re: Diagram for fixing the "Clutch Click" (MK Ultra)
Sorry I didn't read though all the responses to see if your question had been answered but look for your clutch line leading towards your tranny. (Make sure to do this with the car cold because your heat shield will burn). It will have a bleeder attached to it. There will only be ONE black rubber boot attached to the transmission on the left hand (passenger) side of the tranny case. Yank the rubber boot back, and grease the cup area where the hydraulic clutch presses against (you will have to remove the 10mm bolts that hold your clutch pin to the tranny).
98R-1144
May 12, 2007 09:39 AM
jdmcivicferio
Jul 9, 2004 02:15 PM
SAPPHIREblue6SPEED
Sep 13, 2003 12:25 AM
H22Apexi
Jun 5, 2003 01:04 PM
hybrid_eg
Jul 24, 2001 06:49 PM
