Type-S cams (from ATR) in 95 VTEC?
I might be able to buy a set of 2nd hand ATR cams(same as Prelude Type-S) at a good price. Will they work ok if I fit them to my Prelude with new springs and retainers but use the stock P13 ECU?
I know I really need the type-s pistons too for the higher comp. ratio.
Was just wondering?
Was just wondering?
Mine is a H22A2 (UK version) with the 10:1 compression. I have the type-s intake and a sports filter fitted, and a Janspeed 54mm cat-back zorst.
If I buy the cams, and later get a set of new type-s pistons will I need the type-s rods also, or will the stock rods be ok?
is the uk head the same as a usdm head? cuz i heard that the type s cams are not made to work in usdm heads cuz the attack of the cam will wear excessively on the rocker arms.
JinMTVT
Sep 12, 2001 09:50 PM
