Which wire is "hot"?
Old Jun 14, 2003 | 09:59 AM
d357r0y's Avatar
Default Which wire is "hot"?
I'm putting in a 4 wire o2 sensor and I need to know which wire is always on when my motor is running so i can use it as a hot source!!
thanks in advance!
Old Jun 14, 2003 | 02:27 PM
EFsleeper's Avatar
Default Re: Which wire is "hot"? (d357r0y)
uhm. battery? or you could run it off of the thick wires going into the fuse box under the hood. theres a million possibilities.
Old Jun 14, 2003 | 03:54 PM
Artful Dodger's Avatar
Default Re: Which wire is "hot"? (EFsleeper)
he means on the o2 sensor, right?
I don't think any of them are always on, but the two black ones are for the heater, it warms up the sensor in the beginning to give better readings when the motor is cold. EF_LSVTEC told me to connect the white wire to original o2 wire, put one of the blacks to a switched power source, and ground the other two (blue or green, and black). that's probably what you're looking for.
Old Jun 14, 2003 | 06:28 PM
d357r0y's Avatar
Default Re: Which wire is "hot"? (Artful Dodger)
Yes.. Sorry, I should have been more clear...
now, any suggestions to a switched power source I could use?
Old Jun 15, 2003 | 09:32 AM
d357r0y's Avatar
ttt
Old Jun 15, 2003 | 10:10 AM
Frog's Avatar
You want to make the connection in the engine bay or at the ECU?
Old Jun 15, 2003 | 01:42 PM
d357r0y's Avatar
Default Re: Which wire is "hot"? (Frog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frog &raquo;</TD></TR><TR><TD CLASS="quote">You want to make the connection in the engine bay or at the ECU?</TD></TR></TABLE>
In the engine bay would be best/easiest.
Old Jun 16, 2003 | 06:51 AM
d357r0y's Avatar
To the top, I gotta know!
justdoinme23
Aug 25, 2010 04:37 PM
slammedz6ef
Feb 15, 2008 07:46 AM
SimbaDogg
18
Jan 29, 2005 10:42 AM
WhiteVX
Sep 29, 2004 02:12 PM
Pele
Oct 11, 2002 10:57 PM
