HELP: How do you remove the fuel injector electrical connector from the injector?
Old Jul 20, 2001 | 07:42 PM
94GSRNewbie's Avatar
New User
Default HELP: How do you remove the fuel injector electrical connector from the injector?
Subject says it all. Should be an easy one for you guys. It looks like it snaps on, but i don't want to damage the connector or the injector. Did you guys ease it off with a screwdriver? Mine doesn't seem to wanna come off! Thanks ahead of time for your help!
-94GSRNewbie
Old Jul 22, 2001 | 01:38 AM
Lyonel's Avatar
Default Re: HELP: How do you remove the fuel injector electrical connector from the injector? (94GSRNewbie)
There's a square shaped wire that holds the connector in place. You'll need one of those really small flat screw drivers (the ones you use to tighten glasses) to pry it out then get a set of nose pliers to take it off.
Check out the pic and you'll see what I mean
brucifer
Mar 1, 2011 08:38 AM
1PT-SICK
Apr 18, 2006 07:27 PM
v-tec maz
Apr 15, 2006 02:31 PM
