Toda Spec B's on JDM stock CR?
<e> ugh </e>
people run it on stock USDM compression. people run it on 12:1 compression. people run it on 13:1 compression.
On USDM compression they can still use stock injectors.
<insert search plug here> Use the search. </end insert>
Now back to your regularly scheduled program.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highrpmek »</TD></TR><TR><TD CLASS="quote">Is it safe to run toda spec B's with toda valve springs on the stock JDM B18C-R 11.1 comp. Also using the Toda header if that matters.</TD></TR></TABLE>
thats like the perfect "Stock" setup. you can make like 195whp with the proper tuning of course......
nick
nick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drag R »</TD></TR><TR><TD CLASS="quote">
nick</TD></TR></TABLE>
I really doubt you would make 195 whp unless you also had a good 2.5 inch exhaust w/ no cat, hondata, bigger injectors, exceptional tuning, etc. 11.1 is still too low for those cams to make 195 very easily, IMO.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highrpmek »</TD></TR><TR><TD CLASS="quote"> I also have a VAFC </TD></TR></TABLE>
Get a hondata. I had a vafc too, but the hondata went in as soon as the spec b's did.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type R Bob »</TD></TR><TR><TD CLASS="quote">
Get a hondata. I had a vafc too, but the hondata went in as soon as the spec b's did.</TD></TR></TABLE>
Good point. You're lucky, you live close to SGT. I'd go there for a hondata and some tuning..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00MRSi »</TD></TR><TR><TD CLASS="quote">
Guess who built/tuned my motor.
</TD></TR></TABLE>Guess who built/tuned my motor.
im not 100% sure of the diff b/w JDM and Aus spec ITR's.....
but assuming i have the same setup as highrpmek, (stock car running b's + toda springs, std compression) Is there any chance of killing the motor?
I know its not MAXimising the performance of the cams without exhaust and header, but performance will increase correct? The biggest issue is.... will it kill the motor....?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MattY81 »</TD></TR><TR><TD CLASS="quote">The biggest issue is.... will it kill the motor....? </TD></TR></TABLE>
Not if it's built properly.
Black R
Dec 27, 2001 12:43 PM
