WTB: Tein adjustable upper pillow ball mount? where to buy?
i might be buying a set of coilovers (HR) and they have the non adjustable UPBM's id like to get a set for the front. were can you get them and if you have a set let me know. thanks
i hope these arent for a honda, becuase you cannot adjust camber from the pillow ball mount like nissans and others. tein PB mounts for hondas are just Aluminum pieces(non-adjustable)
no way, really. that sucks so if i had the suspension with upbm's what do i need to get... will those skunk2 things work... and y cant you use the ones on the shock tower?
i talked to some dude at jaydm.com and he said it was an extra 300 to get the adjustable upbm's for the crx, in all corners??
lol..
adjustable pillow ball mounts are for nissans/etc with macphereson struts I believe...hondas recieve the solid pillowballs when u use Tein's..
You can adjust camber by getting a new upper control arm [skunk2,etc..]
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by navin »</TD></TR><TR><TD CLASS="quote">adjustable pillow ball mounts are for nissans/etc with macphereson struts I believe...hondas recieve the solid pillowballs when u use Tein's... </TD></TR></TABLE>
the pillowball mounts are supposed to give a stiffer ride/feel. i have the pillowball mounts with my Tein HA's, i like the ride and feel, the only thing that annoys me is sometimes my pillowball mounts will squeek a little. anyone have this problem?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyosupr »</TD></TR><TR><TD CLASS="quote">y cant you do it like nissans, whats the big diff.</TD></TR></TABLE>
Nissans use struts in the front, which replace the upper control arm, therefore the strut/shock is a determining factor in the suspension geometry. On our double wishbone hondas, the shock has no effect on suspension geometry, other than ride height, which is a given. The new 7th gen civics, ep3's, dc5's use macpherson struts in the front, so they have the option of an adj. upper pillowball mount/ camber plate.
makes sense, thanks... those skunk2 camber things you cant get them for a 91crx but you can for a 92-95 ect but what would i have to do to use them? anybody do that before? thanks is there other kits of good quality that you guys have used that would work on a crx or not?
trrbl1bmx
21
Jun 17, 2008 06:14 AM
CivicInspired
Honda Civic (2001 - 2005)
Jul 18, 2007 12:06 PM
93EH6
Dec 13, 2003 03:36 PM
