reading the helms, question about bearing install
Old Jun 13, 2003 | 04:17 PM
Greyout's Avatar
Default reading the helms, question about bearing install
how do you check the clearance on the 'top' bearings? (The bearings between the crank & block). Do you just go by the clearance on the cap-side? If the clearance is too big or two small, do you replace both, or do you always follow the crank/block stamp for the block side and replace only the bridge/cap side? Is there ever a time when you will have different size bearings on the same journal? (one on the top, one on the bottom)?
thx
Old Jun 13, 2003 | 04:27 PM
Greyout's Avatar
Default Re: reading the helms, question about bearing install (JDM LUDE)
oh also - do the main caps have bearing stamps on them, as a size to start with?
Old Jun 13, 2003 | 07:50 PM
Greyout's Avatar
SuckMyDOHC
Jun 15, 2008 11:29 AM
hbyrd8701
Jul 28, 2006 04:24 AM
(puma)
Oct 12, 2005 02:48 PM
Greyout
Aug 15, 2003 11:01 AM
