lower ball joint, please help!!
Old Jun 13, 2003 | 02:34 PM
munscher's Avatar
Default lower ball joint, please help!!
I'm trying to remove my axle and the lower ball joint will NOT come loose. I've beat it with a hammer, i've used the pickle fork (ball joint separator), nothing will break it loose. The pickle fork goes all the way in until the back of the 'U' is resting against the metal, its physcially impossible to any further and still nothing. Yes the castlenut is loosened away so thats not the problem, anybody have ANY ideas? i've tried everything i can think of and am about to give up.
Old Jun 13, 2003 | 04:41 PM
GruvyTune's Avatar
New User
Default Re: lower ball joint, please help!! (munscher)
Use one of those pittman pullers or the type of separator that pushes up against the bolt as you tighten it (like the one in the helm manual). you can buy it for 20 bux from jc whitney
Old Jun 13, 2003 | 05:45 PM
munscher's Avatar
Default Re: lower ball joint, please help!! (GruvyTune)
i finally got it off! i used the advice from a fellow H-T member...
for those who might search later... i put the jack under the castle nut and jacked up with the suspension in tact... once the suspension was compressed i beat on the LCA with a hammer for a lil while until it popped out... oh, and the pickle fork was in there at the same time too.
thanks!
hot hatch man
Sep 26, 2015 11:13 AM
M2nR
20
Mar 10, 2006 10:24 AM
FlyZlow
29
Mar 3, 2006 10:51 AM
munscher
Jun 16, 2003 06:34 PM
wildstallion
Jul 23, 2002 02:09 AM
