weighted shift knobs
can anyone tell me what are some good weighted shift *****? I'm thinking about the Spoon shift **** which weighs in at 440 grams but I was also wondering what else is out there? Also lookin at the GReddy counter-weight ****.
Anything would be appreciated, the shifts in my CRX are especially hard, is this normal in a CRX or is it just that the shift linkage needs to be loosened a bit?
thanks
thanks
mine are hard as hell to put in gear! you need some thick muscles to shift my 89 hatch ! it has a short as hell shifter with clutchmasters stage 4 clutch, it always chirps in 2nd and third even when i dont want it to.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zyntax »</TD></TR><TR><TD CLASS="quote">can anyone tell me what are some good weighted shift *****? I'm thinking about the Spoon shift **** which weighs in at 440 grams but I was also wondering what else is out there? Also lookin at the GReddy counter-weight ****.
thanks
I'd try loosening the shift rod bolt, the one that holds the shifter to the linkage. Maybe even adjust the clutch a bit.
If anyone needs heavy shift *****, I make them out of solid aluminum that you can screw onto your shift stick, instead of those three tiny ones that barely hold it onto the stick
I can custom shape them for you
thanks
</TD></TR></TABLE>I'd try loosening the shift rod bolt, the one that holds the shifter to the linkage. Maybe even adjust the clutch a bit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91hatchcivic »</TD></TR><TR><TD CLASS="quote"> it always chirps in 2nd and third even when i dont want it to.</TD></TR></TABLE>
what tires? I get 2ndl, but not 3rd on my sumitomo's
