Plz help with my header situation...
Old Jun 13, 2003 | 12:46 PM
Mark's Avatar
*Bounty Hunter*
Default Plz help with my header situation...
Mkkk so far Ive got a Apex'i N1 catback...the problem is its 2.36" ID...Well I need a header (Comptech 4-2-1 TIG with 2.25" collector ID) with a 2.25" hi flow car sound cat? Will this create any kind of bottleneck?
Old Jun 13, 2003 | 12:51 PM
Rusty Shackleford's Avatar
Default Re: Plz help with my header situation... (94BlackCivicEX)
dude youre talkin about .16 of an inch. get out your ruler, its not that much. youll be fine.
Old Jun 13, 2003 | 12:57 PM
Mark's Avatar
*Bounty Hunter*
Default Re: Plz help with my header situation... (cpteg)
oh, well I thought even the most meager diff could **** me up lol .
thx for informing me
Old Jun 13, 2003 | 02:11 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94BlackCivicEX &raquo;</TD></TR><TR><TD CLASS="quote">Mkkk so far Ive got a Apex'i N1 catback...the problem is its 2.36" ID...Well I need a header (Comptech 4-2-1 TIG with 2.25" collector ID) with a 2.25" hi flow car sound cat? Will this create any kind of bottleneck? </TD></TR></TABLE>
The Comptech header collector is not 2.25" ID. Since it uses the factory donut gasket like all "USDM" bolt-on headers, it is limited to a 50mm/~2.00" OD collector.
EDIT: The only problem I can think of with the N1 is the flange that bolts to the cat. I am almost positive that it "necks-down" to mate with the small, stock cat. In this case, you should remove the N1's original flange and use a full 2.25" replacement.
The Apex'i N1 is 60mm/2.36", but this measurement is OD, not ID. Since you will be stepping up from the 2.00" OD collector to the 2.25" ID cat., then pairing the 2.25" ID cat. with the 2.36" OD (roughly 2.25" ID) cat-back, there really won't be any "bottle-necks" in the system.
Modified by Padawan at 8:03 PM 6/13/2003
Denny
Dec 3, 2003 08:52 PM
RuskeR
Jun 13, 2003 03:00 PM
RuskeR
Jun 12, 2003 11:09 PM
Mark
Jun 8, 2003 06:41 PM
OBDI JEDI
Mar 12, 2003 10:15 AM
