A6 vs Z6 timing belt ?
Old Jun 13, 2003 | 11:26 AM
89dxhunchback's Avatar
Default A6 vs Z6 timing belt ?
I have an A6 head on a D16z6 block ( nevermind why etc. ), and the Z6 timing belt won't fit onto the A6 head/cam spocket. The tensioner is totally loose, and I can't even pry it on ( even if I could, I wouldn'y run it that way ). So I guess I should use the A6 timing belt ? I guess its longer ?
Old Jun 13, 2003 | 11:59 AM
rioninja's Avatar
Default Re: A6 vs Z6 timing belt ? (89dxhunchback)
I havnt tried it, but the general rule with mini-mes (or your case) is that
you use whichever belt matches the head. So yeah, id try the A6
Old Jun 13, 2003 | 12:15 PM
Default Re: A6 vs Z6 timing belt ? (rioninja)
Thanx. Now to just get the stupid crank pulley bolt off... Turn the compressor to 175 and go buy a 1'' drive socket I guess ( I already have the 1'' drive impact.
There is VERY limited room between the car and the crankshaft pulley with the Z6 swap, it sucks pretty bad.
Ps: I like to call it the "un-mini-me" for a turbo.
ej1noob
11
Jun 16, 2011 12:01 AM
ef-hatchcrap
Apr 18, 2008 03:43 PM
ef-hatchcrap
Feb 21, 2008 04:35 PM
charlie_sohc
Dec 15, 2007 03:17 PM
Iron_Forrix
May 22, 2007 07:37 PM
