Hytech header owners
Old Jun 13, 2003 | 10:41 AM
Reid's Avatar
Global Moderator
Default Hytech header owners
How much did you have to trim off of your engine stiffener to clear the header?
Old Jun 13, 2003 | 10:58 AM
skafia's Avatar
25 Year Member
Default Re: Hytech header owners (Reid)
For a second there reid I thought you where posting: "Hytech Header OWNZ..."
Old Jun 13, 2003 | 11:02 AM
Big Phat R's Avatar
About a 1/2 inch was machined off
Old Jun 13, 2003 | 11:26 AM
ITRJunkie's Avatar
As an alternative, the shop that did my install used a plate from a GSR (I believe).
Old Jun 13, 2003 | 11:31 AM
Reid's Avatar
Global Moderator
Default Re: Hytech header owners (ITRJunkie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRJunkie &raquo;</TD></TR><TR><TD CLASS="quote">As an alternative, the shop that did my install used a plate from a GSR (I believe).</TD></TR></TABLE>
Did they only use the GSR flywheel cover or did they also use the two GSR "stiffeners" also?
Old Jun 13, 2003 | 11:38 AM
ITRJunkie's Avatar
I'm pretty sure it was just the flywheel cover. I didn't think it'd make too much of a difference since John @ HyTech said that the aluminum brace in question was only an addition on 2000 ITRs.
Old Jun 13, 2003 | 12:28 PM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRJunkie &raquo;</TD></TR><TR><TD CLASS="quote">I'm pretty sure it was just the flywheel cover. I didn't think it'd make too much of a difference since John @ HyTech said that the aluminum brace in question was only an addition on 2000 ITRs.</TD></TR></TABLE>
Interesting, I always thought ALL ITR's had this brace.
Old Jun 13, 2003 | 01:59 PM
DarthLuder's Avatar
New User
Default Re: Hytech header owners (Big Phat R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R &raquo;</TD></TR><TR><TD CLASS="quote">About a 1/2 inch was machined off
Old Jun 13, 2003 | 03:04 PM
RTW DC2R's Avatar
Default Re: Hytech header owners (ITR GURU)
for those that dont know, what is the "engine stiffener" and where is it located in that pic?
Old Jun 13, 2003 | 03:06 PM
Chris N's Avatar
Default Re: Hytech header owners (RTW DC2)
Look at the left-most primary, right next to the tranny.
I *Believe* that the clutch cover and stiffener are in that location and seem to have been removed/altered.
I'm sure a more clear answer is forthcoming from someone else.
Old Jun 13, 2003 | 03:44 PM
D's Avatar
D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">
Interesting, I always thought ALL ITR's had this brace.</TD></TR></TABLE>
They do. Crate C5 blocks from acura do not come with the ITR engine stiffner.
Old Jun 13, 2003 | 04:13 PM
TypeRod's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">How much did you have to trim off of your engine stiffener to clear the header?</TD></TR></TABLE>
So to get the header to fit properly in a R, this modification must be done? I wonder why no one ever mentioned that before? I've always had the impression it was just a simple bolt on.
Old Jun 13, 2003 | 04:16 PM
Reid's Avatar
Global Moderator
Default Re: Hytech header owners (TypeRod)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeRod &raquo;</TD></TR><TR><TD CLASS="quote">So to get the header to fit properly in a R, this modification must be done? I wonder why no one ever mentioned that before? I've always had the impression it was just a simple bolt on.</TD></TR></TABLE>
The Hytech is the only header to my knowledge that requires this modification.
Old Jun 13, 2003 | 04:37 PM
jetydosa's Avatar
25 Year Member
Is that blood near the slip joint in the pic???
Old Jun 13, 2003 | 05:17 PM
Black R's Avatar
25 Year Member
.....fwiw, I ran for about a year without the stiffener.
Lip also ran without his and dragged a bunch that way.
Apparently, it keeps the flywheel cool not running a cover.
I finally got mine trimmed with a plasma cutter (no way to upload pics currently), and have some more peace of mind now.
But big phat is right, about 1" to 1/2" should do it.....
While you're at it, you may want to get a skidplate made for the header too.....
Old Jun 15, 2003 | 02:01 PM
ITR#132's Avatar
My 1997 ITR has it.
Old Jun 15, 2003 | 02:07 PM
GokuSSJ4's Avatar
mine has it , i dont think its just for 00 itr's .
thats a big plus on ericks header it clears with no problems .
you will be amaze how many peeps run this brace for all motor
Old Jun 16, 2003 | 08:20 AM
Austin's Avatar
Reid...if I knew that you needed a pic, I would have taken some pics when I had it on a lift Saturday... We even had an extra stiffener that I could have drawn on to show you, bummer.
Austin
Old Jun 16, 2003 | 11:51 AM
ITRbroham's Avatar
shit post warrior
Default Re: (Austin)
Oh, so the tranny stiffener/brace can be possibly modified?
Someone I know with the Hytech header just took simply t00k it off!
figone007
Sep 15, 2007 07:39 PM
neo_
63
Oct 20, 2006 04:24 AM
SpdFrk
May 1, 2006 01:35 PM
edo
May 11, 2005 09:18 AM
KustomCrx
Oct 4, 2004 05:17 PM
