Throttle body question
Is there any benefit and power to be gained from going to a larger throttle body? Looking for a reliable mod, just wondering if this might be a safe way to go.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rguy »</TD></TR><TR><TD CLASS="quote">short and simple. no. </TD></TR></TABLE>
what he said. TB should be one of the last things changed, and the stock one is probably sufficient enough for moderately built motors.
My friend just got a JDM ITR Block swapped to his SiRII head and he still retains the SiRII throttle body. Would he see gains upgrading to an ITR throttlebody or a Spoon 70mm throttle body?
anyone experience a whistle coming from their ITR throttlebody?
I recently installed one on my GSR and it whistles. I removed the Intake thinking this was the culprit, but to no avail.
anythoughts?
YV
anythoughts?
YV
I believe the whistle is more dramatic since you have the S2 IM. It is not the t/b, unless you do not have it mated properly to the IM. If you listen closely enough, you can hear the whistle with the stock IM and CAI. I heard to get rid of the whistling you need to port the t/b to 64mm so it matches the S2 or R IM.
