hardwireing a radar detector
Old Jul 20, 2001 | 10:18 AM
JoshRambo's Avatar
Default hardwireing a radar detector
so i was gonna attempt to hardwire in my radar detector today and well i can't seem to figure out what wire i should use for the power one. i was thinking of hooking it up to my radio so that when the radio is on the radar would come on, but it is a pain in the *** to get to those wires.
anyone ever done this? if so anyone have any hints on what wire i could use.i want something that when i turn on the car it will come on.
thanks in advance
Old Jul 20, 2001 | 10:44 AM
D's Avatar
D
Default Re: hardwireing a radar detector (Gravity)
why don't you use the 12V switched power in the ignition harness.
you want wires that are easy to get to??? How ******* delusional are you?
D
[Modified by D, 2:45 PM 7/20/2001]
Old Jul 20, 2001 | 10:59 AM
itr1275's Avatar
Why, what happen when you want a new radar detector or that one breaks. I've broken 2 already, how about you?
Old Jul 20, 2001 | 11:00 AM
JoshRambo's Avatar
Default Re: hardwireing a radar detector (D)
thanks anyway, but i just got it. i just ran the wire into the fuse box. the fuse with the cig. lighter.
Old Jul 20, 2001 | 11:04 AM
ITR-01-0977's Avatar
New User
There are actually two or three male terminal connectors in your fuse box that you can use...no cutting or splicing...just use a female spade connector and you are done.
Old Jul 20, 2001 | 12:07 PM
len's Avatar
len
Default Re: hardwireing a radar detector (ITR-01-0977)
That sounds to complicated. I was figuring why you just don't tap power from the "ACC" wire that leads to the Radio. This has it's own "ACC" fuse too. That's How I controlled my sister's CD changer. And it is switched on by switching your key to the "ACC" position.
Old Jul 20, 2001 | 12:48 PM
BushPilot's Avatar
New User
Do you have a test light? Use a test light or a volt meter to find a position in your fuse box that is energized with the key on. (as mentioned previously this is the BEST way because it keeps the connections/fuse in ONE place).
Where will you be mounting the detector? One of the advantages to hard-wired is that you can conceal them a little more than with the cigarette adapter. As far as haveing to replace the detector, you should leave enough slack on the detector side of your wire run to be able to re-wire another adapter if needed.
Old Jul 20, 2001 | 12:50 PM
JoshRambo's Avatar
Default Re: hardwireing a radar detector (BushPilot)
i was planning on putting it on the ACC wire of the radio, but it was a pain in the *** to get back to it. so its just in the fuse box. the adapert will fit most radra detectors. so if i need a new one i can just use the sam
Old Jul 20, 2001 | 03:04 PM
onyx00's Avatar
what kind of detector are you trying to do this on?
Old Jul 20, 2001 | 03:42 PM
blaze's Avatar
like ITR-01-0977 said, there are male terminals in the fuse box that are not being used. you can use those for accessories and stuff. or you can splice into the cigarette lighter wire... ...easier to get to, remove and splice.
[Modified by blaze, 4:42 PM 7/20/2001]
vtak2nr
Audio / Security / Video
Sep 8, 2011 08:02 PM
mxl36o
Nov 25, 2006 10:02 AM
andyhoiho
May 29, 2004 07:58 AM
93civcx
Apr 12, 2004 05:41 PM
02AccordCoupe
14
Mar 20, 2003 12:32 PM
