Spoon Earthing System
Did I just waste my money on these? Oh well, I guess it seems to get the job done, although it does bling like a ************.
Couple of things though, the negative terminal connector doesn't fit correctly being that it's probably made for JDM cars, and also the system is made for RHD cars so you gotta use different wires on different mount spots. Oh well.
BTW - What is that bottle of JDM spoon lube for?
Yes you did but the bling factor more then makes up the outrages price that Spoon charges. You could probly make a better Earthing system for less then $25. Well I don't know about the Spoon lube bottle but I am guessing that you use that to prevent rust. Because you are supposed to sand the ground connections and where the wires conection to the body.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skafia »</TD></TR><TR><TD CLASS="quote">Really? can you further explain the sanding process?</TD></TR></TABLE>
Start with a 100 grit paper, then work your way down to a 10,000 grit sandpaper. Wet sand in the end.
Alphabetically, sand the area(s) in the shape of the letter A to Z.
This will ensure that your Spoon earthing kit is complimented by your flawless sanding methods.
Enjoy it.
Enjoy it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skafia »</TD></TR><TR><TD CLASS="quote">BTW - What is that bottle of JDM spoon lube for?
heh.. it's used for when you bend over to pay the spoon bling price for an earthing kit..
sorry, couldn't resist..
the kit sure looks pretty.. How many points does it connect to and what are they? Just curious how different this is from my Tommy_Gunns kit..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mario »</TD></TR><TR><TD CLASS="quote">
Enjoy it.</TD></TR></TABLE>haha, your joking right Mario? 10,000 grit sandpaper? The highest I have seen was like 2500 grit..and that **** was like as ruff as paper...I couldnt imagine how 10,000 grit would be
So it doesn't fit the battery properly, and the wires don't fit your non-JDM car, but other than that.... is there any reason you bought this other than the "Spoon" label?
Only problem that I see is that it's made for the JDM market...the battery is on the "other" side...your cables will be too long, or too short.
well...you also have the cost to, but it has the looks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Austin »</TD></TR><TR><TD CLASS="quote">Only problem that I see is that it's made for the JDM market...the battery is on the "other" side...your cables will be too long, or too short.
As far as being the wrong side it's no big deal.
There's only 4 wires.
VTEC Solenoid
Alternator
Negative Ground
Front Head Ground
The wire that is meant to go to the altenator goes to the VTEC solenoid, and the wire that goes to the VTEC solenoid goes to the altenator. The negative battery ground is where stock is and the front one is replaced easily.
The only problem is that the VTEC solenoid bolts are too small and the wire connectors fall right through them, so I have to get a washer
No big deal.
I got the system from a friend who got it from a friend
Let's just say I got it cheaper than inlinefour.com's advertised price.
</TD></TR></TABLE>As far as being the wrong side it's no big deal.
VTEC Solenoid
Alternator
Negative Ground
Front Head Ground
No big deal.I got the system from a friend who got it from a friend
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScaleExtric »</TD></TR><TR><TD CLASS="quote">haha, your joking right Mario?</TD></TR></TABLE>
Yes, I believe he was.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skafia »</TD></TR><TR><TD CLASS="quote">Did I just waste my money on these? Oh well, I guess it seems to get the job done, although it does bling like a ************.
How do wires "bling" and what's with the swearing in virtually all your posts?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrewCityR »</TD></TR><TR><TD CLASS="quote">
Honda-Tech does not use language filters because we believe in allowing our members to speak freely. Do so within reason however. Excessive use of profanity will be dealt with.
They can bling because they're spoon
Never thought I would say that, heh.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid »</TD></TR><TR><TD CLASS="quote">I guess I just don't understand "bling".</TD></TR></TABLE>
"Bling" is when your bank account's the banks amount. End of story.
Nice avatar though.
Nice avatar though.
Nice avatar though.
SAME TO YOU.
Nice avatar though.
</TD></TR></TABLE>SAME TO YOU.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Urban Business »</TD></TR><TR><TD CLASS="quote">you cant bling a honda.
So to "bling", you need to:
1) Be rich.
2) Let everyone know that you're rich.
Correct?
</TD></TR></TABLE>So to "bling", you need to:
1) Be rich.
Correct?
why not?
</TD></TR></TABLE>why not?
Guest
Posts: n/a
1) Be rich.
Correct?</TD></TR></TABLE>
according to urbandictionary.com:
Jamaican slang that has been adopted by some African American rappers and inserted into popular culture. The term "Bling Bling" refers to the imaginary "sound" that is produced from light reflected by a diamond. See The Silvertones "Bling Bling Christmas" for the earliest known usage of the slang.
so, if we hold true to the deffinition, your honda cannot bling unless it reflects light off a diamond. mabey if you had some $15,000 davins w/ diamond inserts it could start to bling. but ground wires and JDM **** doesnt make you bling. i'll even settle for light reflecting off of chrome.
1) Be rich.
DoH!
