HELP with throttle pedal/idle
Old Jun 12, 2003 | 08:17 PM
JCCOOL43's Avatar
Default HELP with throttle pedal/idle please help
i have a 1988 usdm crx si 1.6 mpfi d16a1
OK I HAVE two questions
first my idle's messed up it sometimes idles at like 2000 rpm and the rest of the time it idles at like 600rpm. i adjust it per the procedure(unplug eacv, adjust tb screw, plug eacv back, reset ecu) and it will fix it for a little while but it will return within the same day. honda dealership says i need a new eacv valve $200 through them. I DO NOT HAVE ANY ECU CODES. I was wondering if which model and year i can swap an eacv from. and if it is the eacv since i am not throwing any codes. the crx workshop manuel says to check for ac and alternator draws? any ideas
second problem
i think this is related to my idle problem. i am driving 80 on the freeway and if ilet go of the gas my car kind of jerks a little bit. when i go to give it gas again it jerks hard . i will take it out of gear while moving and the engine will idle at like 2000rpm
so when the idle is high it afects my throttle?
it seems the throttle is kind of jerky all the time but more so when the idle problem is happening at the same time. i don't know what this is help please
Modified by JCCOOL43 at 5:38 AM 6/13/2003
discoalbicore
Jun 5, 2013 05:44 PM
ITR EG
Apr 12, 2008 09:29 PM
dcskater56
Mar 24, 2008 06:44 AM
stRodda
Jan 13, 2004 04:32 PM
QWKPHKR
Oct 8, 2002 06:37 PM
