if i get 15" rota slips with a 40mm offset and put them on a 88crx
Old Jun 12, 2003 | 07:57 PM
whitemike1644's Avatar
Default if i get 15" rota slips with a 40mm offset and put them on a 88crx
the crx is lowered on neuspeed race springs. 2.25 front and 2.0 rear.
with a b16 swap.
whats the widest tire i can run without rubbing the tire? and will this **** up my handling and turning radius?
only reason i am even considering the 40mm offset is because they are like dirt cheap.
and will they stick out ? like wider than the fender? or will they be even with the body or tuck?
Old Jun 12, 2003 | 08:24 PM
yellowhonda88's Avatar
Default Re: if i get 15" rota slips with a 40mm offset and put them on a 88crx (whitemike1644)
that offset is fine, normal is like +42 or something, my car is lower 2.25 and i have 16x7 wheels with 205's. With my old wheels, that were 7.5" wide, and a 205 tire, the wheel was literally 1/4 away from the rear trailing arm(or whatever that big *** arm is that goes front to back...me tired) so i would say 215 at the max with that offset or you will rub. In the front, you are very limited, cause if you have a wide tire, hit a bump while turning, and WACK, tires eats finder. So, with that lowering, and that offset, i would just do 205, and at most 215.
Brett
Old Jun 12, 2003 | 08:28 PM
Default Re: if i get 15" rota slips with a 40mm offset and put them on a 88crx (yellowhonda88)
oh forgot to mention that they are 15"X6.5"
Old Jun 12, 2003 | 10:07 PM
rice_classic's Avatar
with 15x7" rims with a 35 offset and 205 falken azenis I scraped tire BAD. I have neuspeed sports with a 1.8" drop in the back. I ended up needing to get 99-00' si wheels with a 45 offset in order for the tires to fit underneath the wheel well under hard cornering.. I also rolled my fenders (which I don't recommend.... can someone find me a good cheap body shop? )
Old Jun 12, 2003 | 11:16 PM
Default Re: if i get 15" rota slips with a 40mm offset and put them on a 88crx (rice_classic)
i was thinking about probably getting 195 50's just to be safe........i don't need a huge tire **** i have LSD
Old Jun 13, 2003 | 04:38 AM
Booger's_Rex's Avatar
I got rota's witht the same neuspeed spring set up and 15x6.5 rotas with 205 50 15 tires and i have never rubbed or noticed much difference besides much more traction then stockies
Jesterian
16
Dec 26, 2006 06:34 AM
CRX Toad
May 13, 2005 12:30 AM
CivicSiRacer
10
Feb 28, 2003 05:21 AM
MRDC2
Feb 21, 2003 05:33 PM
Mike D
Jul 31, 2002 09:52 AM
