Details on mini me!!
Old Jun 12, 2003 | 07:28 PM
phatrick2332's Avatar
Default Details on mini me!!
Ive read almost all of the links in the search and im still wondering a bit. Im rebuilding the d16 and i want to go mini me. Can someone point me to a very descript site or give me a run down?
thanks
Old Jun 12, 2003 | 11:18 PM
sethm's Avatar
Default Re: Details on mini me!! (phatrick2332)
ttt
Old Jun 13, 2003 | 02:21 AM
Noahk's Avatar
Default Re: Details on mini me!! (sethm)
What are you wondering? On how to do it, or which is the best route to take?
Old Jun 14, 2003 | 08:02 PM
basically as much as i can find out, what parts to use for the best power and how to go about doing it, the work is no problem, just the technical part is what i dont know.
Old Jun 15, 2003 | 07:45 AM
chirp the 1-2's Avatar
Rebuild your bottom end with factory honda parts, get a honda shop manual put everything to factory spec if the cylinder bores are anywhere out of the factory limit bore and hone the block and get new 10 over honda pistons and rings, make sure the shop knows how to hone a honda block as our rings are different than V8s. Use a Y8 cylinder head have it taken apart checked and tested send it somewhere reputable for a mild port and polish 3 or 5 angle valve job and bowlwork, port match an SI manifold to the ports on the head get a good 4into1 header and aem intake. Im running the same setup with an 89 crx SI bottom end and tranny with a clutchmasters stage 3 clutch and light weight flywheel. The car is a 89 civic dx hatch no ac and took out as much weight as possible! I beat GSRs DOHC SIs and many civics and crxs with B16 swaps!!Oh yeah ECU is crx si with Zdyne B16 conversion 4800 Vtec switchover. If you plan to do all this you will be rewarded with gobs of bottom end torque!! Make sure you break in the motor for at least 1000 miles and dont use synthetic oil till at least 5000 miles!
This is my personal setup and it works!!!
Old Jun 18, 2003 | 12:34 PM
can you give me a quick run down of how much all this cost you if possible?
thanks
foca
May 16, 2008 10:19 AM
foca
May 12, 2008 12:16 PM
SMOOTH97LUDE
Mar 10, 2004 10:53 PM
Spids5
May 28, 2003 04:39 PM
Toxic
Aug 31, 2002 11:58 PM
