ES bushing or prothane bushing better?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">I hear Prothane is softer than ES.</TD></TR></TABLE>
Wow, sorry...
Prothane is harder then ES. Always has been
As for motor mounts tho...For examle ES mounts are soft crap. Prothane are hard plastic.
Wow, sorry...
how did your friend make this comparison?
Neither material is exactly pliable.
Prothane is harder, ES is softer. But before u choose you have to realize that if u go with prothane u are using a harder material which in turn will is unable to absord as much vibration as a softer material, HENCE you will feel such things more.
Give it some thought.. its pretty simple physics.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blubberbutt »</TD></TR><TR><TD CLASS="quote">Quit being a wuss and get both kits installed
You sound like a person that had no clue what they are talking about.
I have the ES kit installed. Why would I install the Prothane kit? that means I need to remove all the bushings I just put in, Kinda moronic huh?
</TD></TR></TABLE>You sound like a person that had no clue what they are talking about.
i actualy got the place racing poly mounts for my car. the engine and trans side mounts. i'm gonna get the es inserts for my front and rear mounts cause they take up more vibrations then the prothane. and for under 20$ its cheaper then gettin new stock mounts.
If you want to eliminate wheel hop completely you would want to combine both kits .. that is what I plan to do.
Modified by blubberbutt at 8:49 PM 6/12/2003</TD></TR></TABLE> youre not going to completely eliminate wheel hop with just bushings..i don't care if team-integra says so either.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loveless »</TD></TR><TR><TD CLASS="quote">actually. I was refering to the bushing for short shifter... but nevertheless you guys have been infomative</TD></TR></TABLE>
I seriously doubt you'll notice any difference between the two with shifter bushings.
Yeah, in terms of one being softer than the other, I think most of us were referring to differences between the suspension bushings. Something like that you would probably be able to tell the difference.
I'm sorry that I "appear" to not have a clue ... according to you.
Here is some food for thought ...
Doesn't appear too moronic to me ... if you'll notice in the pic, the only mount that is shared between the two kits is the rear one. If you want to eliminate wheel hop completely you would want to combine both kits .. that is what I plan to do. I have already purchased the ES bushings but have yet to install them cause I am waiting to buy my Prothane ones and do it all at once. Of course when you have both kits installed I am sure that you will experience a lot more vibrations in the cabin .. however I could care less about this myself.
If you'd like to read more about this, refer here:
http://www.team-integra.net/se...D=296
Now, who doesn't have a clue what they are talking about?
Thanks for all that info. I have a clue and know what I am talking about. I have the Es mounts, front lower 2, rear prothane, passenger side prothane, and drivers side race prothane. Along with the entire ES kit, and soon mugen rear mounts. I have researched them for along time
However.. the topic is "ES bushing or prothane bushing better?"
He never mentioned motor mounts, and everyone else was talking about bushings too, not mounts. Maybe you should read the topics more often.
Ahhh ... sorry for sounding like a 'tard
I must not have read the topic thoroughly nor did I realize that Prothane made shifter bushings therefore I jumped the gun and automatically was thinking about motor mount inserts. And I did word things wrong when I said that both pairs of inserts would TOTALLY eliminate wheel hop .. I know better than that. Anyway that is beside the point.
Sorry for being stupid
in the case of shifter bushings. i have the es ones and liked em alot. got em a long time ago with a dc sports short shifter group buy.
i just ordered the ES master set which includes everything except the motor mountings, trailing arm bushings and sway bar bushings.
I'll let you all know how it goes. should be here in a week so its going in the following weekend.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">I dunno man, my friend told me he compared the two one time and the Prothane was way softer.</TD></TR></TABLE>
i can comment becuase i run both. the Prothane is 100x harder. its almost sickening when you hold the same mount in each brand in hand and feel the diff.
i run prothanes up top and ES on the bottoms and shifter bushings. my car is like a rock . i love it .
rorik
Sep 4, 2006 03:29 PM
Mr.E.G.
Welding / Fabrication
10
Jul 6, 2006 05:10 PM
Power Rev Racing
81
Mar 15, 2006 08:02 AM
