H22A intake manifold
Old Jun 12, 2003 | 12:01 PM
ScareyH22A's Avatar
Honda-Tech Gold Member
Community Builder
Default H22A intake manifold
Who makes an intake manifold for H22A? I have a 5th gen Prelude 5spd. I'm waiting for the Skunk2 but heard it not available yet. Any word on it?
Old Jun 12, 2003 | 12:03 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: H22A intake manifold (ScareyH22A)
are you staying N/A or are you gonna turbo?
Old Jun 12, 2003 | 12:14 PM
ScareyH22A's Avatar
Community Builder
N/A for now, but why? I wanna p/u a new throttle body like some thats recommended from peepz on my other thread and then I want a intake manifold to compliment it. I can bore it out some myself to matchport w/the throttle body.
Old Jun 12, 2003 | 12:23 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: (ScareyH22A)
well, if you were turbo charging, i'd suggest a Golden Eagle Intake manifold, but since you are staying N/A, i'd say go with a stock one ported out, or wait for the Skunk2
Old Jun 12, 2003 | 12:25 PM
MugenPoweredLude's Avatar
you can wait for the Skunk2
Old Jun 12, 2003 | 12:28 PM
Prelude Vtec 23's Avatar
Default Re: (MugenPoweredLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenPoweredLude &raquo;</TD></TR><TR><TD CLASS="quote">you can wait for the Skunk2</TD></TR></TABLE>
Because only GOD knows when they will ever release it.
Old Jun 12, 2003 | 12:30 PM
thank you for finishing that.....lol
Old Jun 12, 2003 | 01:57 PM
TimeRacer's Avatar
I have a ported H22 intake manifold for sale. Take a look at my sig.
Old Jun 12, 2003 | 02:51 PM
Final Flash's Avatar
Default Re: (Prelude Vtec 23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude Vtec 23 &raquo;</TD></TR><TR><TD CLASS="quote">
Because only GOD knows when they will ever release it.</TD></TR></TABLE>
Amen. I check their site weekly and see the same **** "TBA". That straight sucks.
Old Jun 12, 2003 | 03:19 PM
rjr162's Avatar
Default Re: (Boosted97Lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted97Lude &raquo;</TD></TR><TR><TD CLASS="quote">well, if you were turbo charging, i'd suggest a Golden Eagle Intake manifold, but since you are staying N/A, i'd say go with a stock one ported out, or wait for the Skunk2</TD></TR></TABLE>
Just remember, the power curve under boost or N/A reacts nearly the same with an Intake Manifold change. A ported and polished factory intake manifold will make more power than most aftermarket IM's in the powerband our cars run. Now if you're looking to run it out to 8000+ it's not a bad idea to switch to an aftermarket (STR, etc, etc) as they shift the power band to the higher rpms. Again, just remember the power band is affected nearly the same N/A or FI
Old Jun 12, 2003 | 04:34 PM
ScareyH22A's Avatar
Community Builder
I don't believe that u have to rev past 8000 to make more power w/an aftermarket I/M. I know for sure ('cause I've seen it plenty of times on B16 motors) that when u do put on like the STR (welded box type) I/M, u need a lot more than N/A flow to get any benefit. Actually, I noticed that a Skunk2 I/M makes more power on like the B16 than the STR did N/A. I'm not looking to install a box type I/M, I'd be happy w/a nicely ported stock manifold. But instead of sending mine out to a machine shop (that may or may not do a good job), I'd rather just buy one from like Skunk2 or someone. That brings me back to the question, "Who makes intake manifolds for H22A?"
Old Jun 12, 2003 | 06:26 PM
Boostless97Lude
Guest
Posts: n/a
that's b/c sheetmetal style IM like the golden eagle, or the str, or the inlinepro, or the venom etc, is made for turbo performance, not for N/A
Old Jun 12, 2003 | 07:02 PM
rjr162's Avatar
the SCCA champion Del Sol in conjunction with Land Speed Racing have a really good book out that dyno's alot of parts to give you an idea of the affects of each... and on the Del Sol they tried the factory b16 IM with a mild P&P, a type R, STR, jun... and the stock B16 did better than any up until about 7700, and that's where the STR and JUN crossed the stock's HP and started to really perform... only problem is the car redlines a few rpm's past that which means you're not using the STR or JUN's powerband. Granted this is the B16 but the IM's for the H22 are most likely designed to flow the same way... since the runners are shorter and has a larger plen(ok i always forget this damn word lol). Anyhow, I'm interested myself in what the Skunk2 does as it seems to be more inline with the factory design which should prove to give you the power in the stock rpm range.
Old Jun 12, 2003 | 07:33 PM
fastwanabe's Avatar
Default Re: (Final Flash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Final Flash &raquo;</TD></TR><TR><TD CLASS="quote">
Amen. I check their site weekly and see the same **** "TBA". That straight sucks.</TD></TR></TABLE>since last week I've been emailing them on a daily basis, maybe you guys should do the same and see if that makes a difference.
Old Jun 12, 2003 | 07:52 PM
Cottonwoodz's Avatar
Default Re: (rjr162)
Plentium
Old Jun 12, 2003 | 09:21 PM
Default Re: (fastwanabe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastwanabe &raquo;</TD></TR><TR><TD CLASS="quote">since last week I've been emailing them on a daily basis, maybe you guys should do the same and see if that makes a difference.</TD></TR></TABLE>
Dude, I was doing that once a week like LAST SUMMER. Some chick would tell me that it was in R&D and would be available soon. When they got tired of me, their solution was to start ignoring/stop answering my e-mails.
Old Jun 13, 2003 | 05:18 AM
rjr162's Avatar
Default Re: (Cottonwoodz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cottonwoodz &raquo;</TD></TR><TR><TD CLASS="quote">Plentium </TD></TR></TABLE>
I gotta write that down lol. Thanks!
Old Jun 13, 2003 | 06:07 AM
Boostless97Lude
Guest
Posts: n/a
i hope you were joking, it's Plenum
Old Jun 13, 2003 | 07:19 AM
Boostless97Lude
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by From STR's Website &raquo;</TD></TR><TR><TD CLASS="quote">
<FONT SIZE="4">str drag manifold</FONT>
the original drag manifold! often imitated never duplicated. custom intake manifolds have always been used by professional drag racers. this becomes necessary when the cylinder head demands greater than the stock manifold. str manifolds have been dyno tested and track proven each manifold is precisely engineered with tapered runners and a custom <FONT SIZE="2">plenum.</FONT> ensuring exact fitment and undisturbed air flow every time. the manifold is cnc billet aluminum, accommodates all factory sensors including iac. our manifolds have been used by almost all of the fastest racers in the industry. </TD></TR></TABLE>
Old Jun 13, 2003 | 07:36 AM
LowFlyin''s Avatar
What about the EuroR IM?
Old Jun 13, 2003 | 10:52 AM
KTeller8's Avatar
Venom has one also
Old Jun 13, 2003 | 01:27 PM
KCHybrid's Avatar
Default Re: (KTeller8)
The newer venom one is more rounded compared to the old box type. Any one seen it yet? Kepp in mind also I think you have to add the idle air controls to most of these box types. They do not have provesions for the idle air control. However newer ones may. I just know the gen 1 venom did not.
Old Jun 13, 2003 | 03:42 PM
rjr162's Avatar
i hope you were joking, it's Plenum</TD></TR></TABLE>
he was close enough... or atleast closer than i got lol
Old Jun 13, 2003 | 05:31 PM
crj_lll's Avatar
Default Re: (LowFlyin')
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LowFlyin' &raquo;</TD></TR><TR><TD CLASS="quote">What about the EuroR IM?</TD></TR></TABLE>
I was wondonering the exact same thing. I have heard it bolts right up. Has anyone had any experience with the accord euro-R intake?
Also, will an H23 IM work on an H22??? Is the stock bore, bigger???
Old Jun 13, 2003 | 05:46 PM
HondaHomie's Avatar
theres a guy i forgot either on this forum or po.com who got the skunk2 took pics of it to.
