Need help how to Jump an automatic neutral switch!!!!
I have a underdash automatic harness with my 95 Integra gsr because its the only harness the junk yard had. Does anyone know how to bypass this ?? Thanks The car is a 5 spd
You have to splice up some wires that goto the auto shifter...two 12 gauge wires..those are part of the starter circuit, one black with a white trace and one black with a red trace. The color changed to both black with a white trace I think in some other years. They're both part of one connector...they're the two biggest wires in the center of the connector..you just splice those two together and your car should start..... you really need to just spend the 13 dollars and get a haynes manual to see the wiring diagram and understand what you need to do.
rmc
rmc
Thanks bro ..I have a Integra Service manual in pdf, but the diagrams werent all that. Thanks though Hopefuly it will work
DA9Sleeper
Apr 29, 2011 02:56 AM
