Endlink part number?
Just picked up some SPC rear lower control arms for my 95 civic DX. I am going to be installing an ITR 22mm rear sway bar. I know all the parts that I need (including the beaks kit) except the part numbers for the endlinks. On my other post... https://honda-tech.com/zerothread?id=359054 a guy with a 96-00 told me "52303-ST7-Z00 Link Compensator" I wasn't sure if this is the same for the 92-95 civics or if it is a different part number. And just want to make sure, is this everything I need...
Qty Ref# Part No. Description
1 5 52300-ST7-Z01 22mm Rear Sway Bar
2 6 52303-ST7-Z00 Link Compensator
2 7 52308-SS0-000 Sway Bar Holder
2 8 52312-ST7-Z00 Stabilizer Inner Bushing Collar
2 9 52314-ST7-Z00 Stabilizer Linkage Bushing
2 10 52315-ST7-Z01 Stabilizer Bushing
2 11 52316-ST7-Z00 Stabilizer End Bushing
4 27 93403-08020-08 8x20 Bolt-Washer
2 37 90175-ST7-Z00 8x35 Stabilizer End Bolt
2 30 90120-SB0-003 10x24 Shock Absorber Lock Bolt
2 40 94103-10400 10mm Plain Washer
2 Rear Lower Control Arms from a civic 4 door or GSR, or aftermarket
1 Beaks kit
Thanks
1 Beaks kit
Thanks
I have the endlinks I took off of a type r sway bar that I am going to install on my ek. They are in my garage and I have no need for them. They also come with the bushing from the sway bar to endlink. They are in good shape. IM me if interested.
