Ingalls camber kit squeaking??
I had the ingalls camber kit installed front and rear. The fronts are polyurethane and where lubed as instructed. The rears are rubber and thus no lubing is necessary. Well the rear squeaks like *HELL*. Did the installer **** up something or what is the deal. I tried to spray some silicone at it but no luck. Any such experiences anyone?
i had a problem like this only it was making noise when cornering, thing was during the install of the rear camber kit we adjusted it a lil bit to make installation easier, well we turned the wheels out too positive and the tire would rub against the 1/4 panel, check that... try adjusting your camber in a lil bit, if that works, go get it aligned
alright, there's washers on the bolt going through the rear of my ingall's kit that have like 'fingers' on them to grip the bolt. mine squeak like crazy and need to fix it before i go nuts. anyone have any idea as to what to do, and has anyone SUCCESSFULLY eliminated the squeak?
i have a 99 civic w/ rear ingalls kit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bEG »</TD></TR><TR><TD CLASS="quote">my neighbor had the same thing on his prelude, he used grease, i think like cv axle greese on it, and it does not make noise anymroe. period.</TD></TR></TABLE>
did he have to disassemble the kit to lube it? where did he get replacement washers to reassemble?
i took silicone lubricant, the spray one with small straw jammed it in every little crevas i could and no more crunching noise for me. mine never squeeked. always crunch crunch
Modified by phantom_sol at 10:55 AM 4/3/2004
i have the poly's in the rear and they squeek all the time. i really don't see how you can truly grease them but it don't hurt to try. this may soud loco, but i like the squeeky sound and makes me feel like i got my money's worth. but if i bought rubber ones and they squeeked i be pissed.
