I wanna go faster!!
Old Jun 11, 2003 | 11:35 PM
94hondaLS's Avatar
Default I wanna go faster!!
I have a EG with an LS swap and this thing isn't what I expected(its still slow) I cant even beat a 2000 Si in the 1/4 mi. what can I do to make it faster for CHEAP(under $250) until I save enough cash for turbo? Any suggestions other than nitrous?
Old Jun 11, 2003 | 11:38 PM
Jimmy's Avatar
Global Moderator
Default Re: I wanna go faster!! (94hondaLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hondaLS &raquo;</TD></TR><TR><TD CLASS="quote">I have a EG with an LS swap and this thing isn't what I expected(its still slow) I cant even beat a 2000 Si in the 1/4 mi. what can I do to make it faster for CHEAP(under $250) until I save enough cash for turbo? Any suggestions other than nitrous?</TD></TR></TABLE>
save up a little bit more and then go to a junkyard and buy a vtec head.
Old Jun 11, 2003 | 11:40 PM
WongFeihung's Avatar
Default Re: I wanna go faster!! (USDMDC2)
yummy..go lsvtec..you wont regret it.
Old Jun 11, 2003 | 11:41 PM
VX's Avatar
VX
You can always strip you car to shed some weight off, and free up some power... and it's basicly free.
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMDC2 &raquo;</TD></TR><TR><TD CLASS="quote">
save up a little bit more and then go to a junkyard and buy a vtec head.</TD></TR></TABLE>
lol i dont know where you live but you dont just find b series vtec heads in junkyards most places
and i would say save for the turbo
Ls + boost =
Old Jun 11, 2003 | 11:53 PM
CristalCleanCivic 97 EX's Avatar
For that much you could do a number of things.
Some things I can suggest to get started is to change your intake piping, intake mainfold, fuel rail, buy a fuel regulator, get and play with a v-tech controller(Apexi, alittle more than $250, but not much), a short shifter, a header, new b-pipe, free flowing muffler, the list goes on and on...
Hope this gave you some fresh ideas.
Old Jun 12, 2003 | 07:55 AM
Jimmy's Avatar
Global Moderator
Default Re: I wanna go faster!! (CristalCleanCivic 97 EX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CristalCleanCivic 97 EX &raquo;</TD></TR><TR><TD CLASS="quote">For that much you could do a number of things.
Hope this gave you some fresh ideas. </TD></TR></TABLE>
someone wasnt paying attention...if he has a LS motor...how would a vtec controller help him??? and btw you spelled vtec wrong
also around here there are import junkyards...i see all kinds of si's all the time
but very rarely do i see a gsr
Old Jun 12, 2003 | 08:11 AM
nY's FiNeSt's Avatar
learn how to drive first
Old Jun 12, 2003 | 08:26 AM
Nebula's Avatar
New User
Default Re: I wanna go faster!! (nY's FiNeSt)
Yeah you should be getting beat by a 2000 si, I think you need to practice some more at 1320.
Old Jun 12, 2003 | 08:42 AM
JDMC5's Avatar
Default Re: I wanna go faster!! (Nebula)
If you wanna go faster, then dont buy a honda/acura
Old Jun 12, 2003 | 09:04 AM
length's Avatar
Hope this gave you some fresh ideas. </TD></TR></TABLE>wow read what the man said. its an LS swap not a vtec swap .. Duhhh yup yup
redline201's Avatar
2 free mods
1. strip the interior
2. take off rear bumper cover
and with your $250
buy some bfg gforce drag radials
that should take some tenths of your 1320
edit
the *** on that girl in your avatar is amazing
i cut off a toe to hit that
Modified by redline201 at 2:46 PM 6/12/2003
Old Jun 12, 2003 | 12:54 PM
94hondaLS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nY's FiNeSt &raquo;</TD></TR><TR><TD CLASS="quote">learn how to drive first</TD></TR></TABLE>I usually out launch my opponents or at least neck and neck with them so I dont think its my driving. Its usually at the top of 2nd gear they start pulling on me. Also on hot days and some nights I feel a power loss at high rpm's. it feels like the cars missfiring or the clutch is slipping. cant pin point it yet. it just started recently too.
Old Jun 12, 2003 | 02:00 PM
D-t's Avatar
D-t
I'd say try to strip up your car a little, you know just get rid of excess tar or something. Try to get a b16 v-tec head. More free flowing, and you know when that vtec kicks yo! Other than that, save up for some basic bolt-ons, and then go turbo. But I would first get a b16 head.
Old Jun 12, 2003 | 02:05 PM
ransack's Avatar
Default Re: I wanna go faster!! (VeLoXHaTcH)
if you cant beat in Si in your EG, you need more practice...
under 250, I would say, yeah, slicks
Old Jun 12, 2003 | 03:10 PM
tangb2023
Guest
Posts: n/a
learn how to shift,,cause 2000 si is slow if stock..250 get u a better clutch to beat si. i beat a si tith stock d16z6 before
Old Jun 12, 2003 | 03:28 PM
DOMKID's Avatar
first of all make sure the motor is running right.
1. Do a compression test and post the results
2. Make sure timing is right , on the distributor side and on the timing belt.
3. Do some basic maintnace( fuel filter, air filter, spark plugs and wires etc...)
keep practicing, you should be able to take the SI , if hes stock.
If worse comes to worse, save about 100 bucks more and get a used nitrous kit. Run a 50 shot for a while.
Old Jun 12, 2003 | 03:56 PM
Ya@inlinePRO's Avatar
Default Re: I wanna go faster!! (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">
Ls + boost = </TD></TR></TABLE>
hahah just what i was thinking. because vtec heads just come and go right? ehhehe
i say boost bro. its all about the boost.
Old Jun 12, 2003 | 04:19 PM
976's Avatar
976
New User
Default Re: I wanna go faster!! (kwik2nec)
http://www.cheapturbo.com
Build a god damn turbo.
I've seen a stock Dx with a B18B (stock as well, besides a cylinder guard) runs 11's at 11 psi.
The driver was a girl BTW.
Turbo!
Old Jun 12, 2003 | 04:56 PM
redline201's Avatar
Default Re: I wanna go faster!! (w00t!)
yeah definatly check your timing
Modified by redline201 at 9:31 PM 6/12/2003
Old Jun 12, 2003 | 05:00 PM
ThisLittleSleepeR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by w00t! &raquo;</TD></TR><TR><TD CLASS="quote">
Turbo! </TD></TR></TABLE>
damn, gotta love girl racers
Old Jun 12, 2003 | 06:30 PM
shermanyang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by w00t! &raquo;</TD></TR><TR><TD CLASS="quote">http://www.cheapturbo.com
Turbo!! nuff said!!
Old Jun 14, 2003 | 12:45 AM
BeavisB16's Avatar
Default Re: I wanna go faster!! (shermanyang)
Get a b16 tranny. Those long gears on the LS are a drag.
Old Jun 14, 2003 | 04:40 AM
VRD^don's Avatar
i'm going to win..i have to win..you need some NAWZ man..get the big bottle..two of them..naw just joking..ls/vtec baby and turbo the ****..
Old Jun 14, 2003 | 08:45 AM
B18C2_sedan's Avatar
Default Re: I wanna go faster!! (sohc_vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc_vtec &raquo;</TD></TR><TR><TD CLASS="quote">i'm going to win..i have to win..you need some NAWZ man..get the big bottle..two of them..naw just joking..ls/vtec baby and turbo the ****.. </TD></TR></TABLE>
yea that would be cool man.
