Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
HF Jack $149....
Old Jun 11, 2003 | 07:39 PM
.RJ's Avatar
.RJ
Default HF Jack $149....
http://www.harborfreight.com/c...47246
Thats a g00d deal. I need to exercise some serious restraint.
Old Jun 11, 2003 | 09:22 PM
baonest1's Avatar
Default Re: HF Jack $149.... (.RJ)
damn things are always on sale. whats the word on these. i hear quite a few aren't working very well.
whats the word on the warranty?
Old Jun 11, 2003 | 09:24 PM
markw's Avatar
Default Re: HF Jack $149.... (baonest)
We had issues with our club jack, but it was because someone stored it on it's side. bled it and it works fine.
Old Jun 11, 2003 | 10:29 PM
KekeK-18's Avatar
I got mine last week. For some reason, when I jack up the car, I can hear air leaking and the jack sink slowly...? Do I need to bled it or do you guys think its a faulty jack? Anyone have the bled valve that I can borrow because I think I have never gotten one.
Old Jun 12, 2003 | 04:02 AM
Evan55's Avatar
Default Re: HF Jack $149.... (KekeK-18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KekeK-18 &raquo;</TD></TR><TR><TD CLASS="quote">I got mine last week. For some reason, when I jack up the car, I can hear air leaking and the jack sink slowly...? </TD></TR></TABLE>
this is exactly what mine does. I hate this POS jack.
Bleeding does nothing.
Old Jun 12, 2003 | 04:09 AM
Willard's Avatar
Default Re: HF Jack $149.... (elgorey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elgorey &raquo;</TD></TR><TR><TD CLASS="quote">I hate this POS jack.</TD></TR></TABLE>
hammer + nail = exactly
Old Jun 12, 2003 | 04:15 AM
Apocalypse's Avatar
We have two. One had to be bled for it to work properly but the other has worked perfectly from day 1.
Old Jun 12, 2003 | 04:42 AM
madhatter's Avatar
From: boldly scornful of higher mental function, US
Default Re: HF Jack $149.... (Apocalypse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apocalypse &raquo;</TD></TR><TR><TD CLASS="quote">We have two. One had to be bled for it to work properly but the other has worked perfectly from day 1.</TD></TR></TABLE>
Ditto. Even if it slowly leaks, it still weighs 1/4 of what the steel jacks out there do. Jack it up and stick a jack stand under there.
Mine has worked flawlessly. (knocking on wood)
Old Jun 12, 2003 | 04:50 AM
.RJ's Avatar
.RJ
Default Re: HF Jack $149.... (madhatter)
The only thing stopping me from buying one now is that i'm already taking a trip to HF this weekend for an electric impact wrench and a bunch of other goodies. My visa will burn about $250 worth
Old Jun 12, 2003 | 04:59 AM
baonest1's Avatar
i was there this past weekend.. they had the jacks at $199.
Apocalypse's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madhatter &raquo;</TD></TR><TR><TD CLASS="quote">Even if it slowly leaks, it still weighs 1/4 of what the steel jacks out there do.</TD></TR></TABLE>
Plus, some of our body panels are so low to the ground that we'd have to pull up on the fender just to get our old jack underneath. The HF jacks have solved 2 problems for a fraction of the cost of other jacks. If someone has one that doesn't work, send it back and get a new one.
Old Jun 12, 2003 | 05:56 AM
.RJ's Avatar
.RJ
$4 from scrap 2x4's solved this 'problem' for me as well. Just drive up on the wood planks on the front.
Old Jun 12, 2003 | 05:57 AM
Evan55's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">$4 from scrap 2x4's solved this 'problem' for me as well. Just drive up on the wood planks on the front.</TD></TR></TABLE>
$4? pshhh you overpaid. I got mine for .33 each
Home despot scrap wood bin 0wnz
Old Jun 12, 2003 | 05:59 AM
.RJ's Avatar
.RJ
nice... you'll need them with your arrrrr
Old Jun 12, 2003 | 07:00 AM
Apocalypse's Avatar
Then you have to line them up and move your car every time you want to change tires. At Summit in May, when we changed tires 9 times from the seriously unpredictable weather I wouldn't want to be shifting cars around in a downpour just so I can jack them up. Not only are you wasting gas at $4.50 (or whatever) a gallon but you're also fouling your plugs by not leaving the thing running long enough.
Old Jun 12, 2003 | 07:21 AM
honda_joe's Avatar
.33?
Go ask somebody who works in the lumber area for the ones that come with new bunks of lumber. They use them to space the bunks so you can fit the forks in. I work for a small hardware store and we throw a TON of them away.
Old Jun 12, 2003 | 07:40 AM
Shortbus's Avatar
Default Been debating this myself. Talked to HF online, and they say that the stores will
match the online price as long as it's valid at the time. I printed out todays online price, and may go pick one up today. If you wanna bite the bullet for an awesome jack, the Brunnhoelzl Warrior is on sale at Pitstopusa.com...... My only concern is that "losing" a 500 dollar jack would be worse than "losing" a 149 dollar jack in case someone decided they liked it more than I do.
Decisions, decisions...
http://www.pitstopusa.com/BRUPITJACKS.asp
Old Jun 12, 2003 | 08:03 AM
Vitt1's Avatar
Default Re: Been debating this myself. Talked to HF online, and they say that the stores will (Shortbus)
Even at $149 for the HF, I still rather pass it up and buy the AC DK20 for about $240. Even though it's not aluminum, I can still deal with the 64 lb weight; and it's much more durable, not to mention a 5 year warranty.
http://www.alltiresupply.com/M..._LCSJ
Old Jun 12, 2003 | 08:34 AM
stevel's Avatar
Default Re: HF Jack $149.... (markw)
Well, mine came with the bleeder bolt that replaces the solid bolt right on top. When I first used it I didn't put the bleeder bolt in and it wouldn't even jack the car up. I put the bleeder bolt in and left it in (the instructions say you can) and air comes out whenever I jack up the car. It says that it will constantly bleed when needed. Haven't had any issues so far.
s
Old Jun 12, 2003 | 08:36 AM
stevel's Avatar
Default Re: Been debating this myself. Talked to HF online, and they say that the stores will (Vitt1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vitt1 &raquo;</TD></TR><TR><TD CLASS="quote">Even at $149 for the HF, I still rather pass it up and buy the AC DK20 for about $240. Even though it's not aluminum, I can still deal with the 64 lb weight; and it's much more durable, not to mention a 5 year warranty.
http://www.alltiresupply.com/M..._LCSJ</TD></TR></TABLE>
my friend has that jack at this shop and it's low enough profile but the front jack point under the radiator is set back a little and that jack ends up hitting the bumper before it hits the jack point. The HF one doesn't do that. It is a nice jack but I wouldn't want to be lugging it to the track.
s
Old Jun 12, 2003 | 08:44 AM
Evan55's Avatar
Default Re: HF Jack $149.... (stevel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevel &raquo;</TD></TR><TR><TD CLASS="quote">I put the bleeder bolt in and left it in (the instructions say you can) and air comes out whenever I jack up the car. It says that it will constantly bleed when needed. Haven't had any issues so far. </TD></TR></TABLE>
it also spurts oil, and will leak oil if you put it on its side or upside down. Keep that in mind when you load it in the car for the track.
Old Jun 12, 2003 | 08:55 AM
.RJ's Avatar
.RJ
Then you have to line them up and move your car every time you want to change tires. At Summit in May, when we changed tires 9 times from the seriously unpredictable weather I wouldn't want to be shifting cars around in a downpour just so I can jack them up. Not only are you wasting gas at $4.50 (or whatever) a gallon but you're also fouling your plugs by not leaving the thing running long enough.</TD></TR></TABLE>
Just put them under the tires... its not my fault you're too lazy just to push the car up on them.
Old Jun 12, 2003 | 05:45 PM
rex_boy's Avatar
similar to this one at 1/4 the cost.
HF
http://www.intercomp-racing.com/fr_specialty.htm
Old Jun 12, 2003 | 05:56 PM
krshultz's Avatar
The quality control sounds like it just isn't there. I guess I'll pass. Inconsistent results + my luck with equipment = busted. Every time.
Old Jun 12, 2003 | 06:00 PM
phat-S's Avatar
Default Re: HF Jack $149.... (krshultz)
Sorry this is frustrating to me and its probably an overreaction but ... guys complaining that they lift a 2k+ lbs. car using one of the fingers and the pad breaks, guys saying they store it upside down and it leaks. That's not quality control issues - its misuse of product. If it needs to be bled, they send a bleed screw with it. I have had great use out of mine and have seen a ton of them in the paddocks at races over the last year, not one of them was in a trash can.
