wat shock should i use with ground control? (searched)
finally my stock shocks went out on me after 2 year with the gc. now i want to know what kind of shocks should i get? I was thinking kyb agx or something adjustable. any opinions? where is the cheapest place i can find these? thanks for any help. i heard that there were some aftermarket shock that will not work with ground control coilovers, is this true and which ones are they?
It depends on a lot of factors, like what spring rate are you going to go with. If you go with a high spring rate you should go with revalved Konis. And Konis are probably your best bet with an adjustable coil-over system. GC and married their coil overs with konis perfectly.
Oh and for more info search under "ground control" under the prelude forum, and look through recent threads and archieves.
steve00si
19
Nov 30, 2004 07:37 PM
