How do I get rid of the CEL?
Old Jul 19, 2001 | 06:17 PM
Vtec-R's Avatar
New User
Default How do I get rid of the CEL?
My CEL came on a few days ago and when I checked my gas cap it was very loose. I assume that it came on because of this but I need to know how to get it to go out. Thanks.
Old Jul 19, 2001 | 06:31 PM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: How do I get rid of the CEL? (TypeR1159)
There is a small button about halfway between your steering wheel and the pedals which will reset your CEL. feel around with your right hand and you should find it. If you brought your legs straight up while driving and hit the bottom of your dash, it would be like where your shins are I think. Hope this helps.
Old Jul 19, 2001 | 06:35 PM
Vtec-R's Avatar
New User
Default Re: How do I get rid of the CEL? (Ross1013)
Is this button different that the button that resets the Maintenance required light?
Old Jul 19, 2001 | 06:39 PM
Ross's Avatar
25 Year Member
Community Builder
Ah **** thats the one I was talking about. DOH! I didn't read your post carefully enough, it was too damn long!
[Modified by Ross1013, 3:40 AM 7/20/2001]
Old Jul 19, 2001 | 06:57 PM
nsxtcjr's Avatar
New User
Pull the correct fuse for a few seconds. On my other Honda, it's the clock fuse. I'm not sure which fuse it is on the ITR, but you might try the clock fuse. (You will need to reset the clock and radio station buttons afterwards.)
If you have the service manual, the procedure for pulling the code, diagnosing, and resetting is in the "Fuel" section, I think.
[Modified by nsxtcjr, 9:59 PM 7/19/2001]
Old Jul 19, 2001 | 08:06 PM
kenji's Avatar
25 Year Member
Default Re: How do I get rid of the CEL? (nsxtcjr)
The correct way to reset your CEL is to either remove the negative battery terminal for a few seconds or remove the 'backup' fuse in the underhood fusebox.
-kenji
greeen ranger
Jun 16, 2013 06:38 PM
Sean2010
10
Sep 5, 2011 04:21 AM
Malakai
Mar 16, 2005 02:52 PM
Bbasso
Jan 1, 2003 03:21 PM
