valve ajustment
Old Jun 11, 2003 | 05:04 PM
minitec's Avatar
Default valve ajustment
sup yall,
have 107k miles on my d16. do i need a valve adjustment? also, how much do they cost?
Old Jun 11, 2003 | 05:16 PM
b18bcx's Avatar
Default Re: valve ajustment (minitec)
how many miles have you put on it? Did you just get the car? Do you know the service history? I would do it if I were you.
Old Jun 11, 2003 | 06:37 PM
blueeg's Avatar
yes, do it. should be around, i dunno $45 bucks.
Old Jun 11, 2003 | 08:34 PM
soslodelsol's Avatar
valve job is around $80- $90 bucks depending on where you do it!!!
and valve adjustment is around $40- $50 bucks also.
Old Jun 11, 2003 | 09:12 PM
mugen76's Avatar
Default Re: (soslodelsol)
forget that, buy your own valve adjustment tool from snap-on, get some feeler gauges.. learn how to DIY on honda-tech and charge your friends 30bux to do their adjustments for the rest of your life. teach a man to fish.........
Old Jun 11, 2003 | 10:08 PM
mugensport9's Avatar
Default Re: (mugen76)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugen76 &raquo;</TD></TR><TR><TD CLASS="quote">forget that, buy your own valve adjustment tool from snap-on, get some feeler gauges.. learn how to DIY on honda-tech and charge your friends 30bux to do their adjustments for the rest of your life. teach a man to fish.........</TD></TR></TABLE>
agreed, learn to do it yourself, and u can do it all the time when you need to
Old Jun 11, 2003 | 10:10 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (mugensport9)
it's simple. Then you can do all your friend's cars and make 20 bucks in 20 minutes time
&lt;----Evan, who does so
Old Jun 11, 2003 | 11:54 PM
AlphaQup's Avatar
Default Re: (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">it's simple. Then you can do all your friend's cars and make 20 bucks in 20 minutes time </TD></TR></TABLE>
Agreed , all you need is a helms manual. H-T had some threads with downloadable EG helms manual in pdf format. do a search mah brotha
Old Jun 12, 2003 | 12:36 AM
VTHokie's Avatar
Default Re: (AlphaQup)
If you have never done it yourself i suggest you do it with someone that has done one before. I noticed you are a newb, but of course that doesn't explain your background with cars. Anyway if you have had enough experience with cars here is the how to, its pretty simple actually. (This is on a b series motor, but the procedure should be very similar, you just have 1 cam. http://www.c-speedracing.com/h...t.php
Old Jun 12, 2003 | 02:14 AM
stripes777's Avatar
do u kno how much this process cost? if i do it, i think im just going to get a new valve cover gasket kit, which is like around 45 bucks i think
how much is the valve adjustment kit?
btw, what does adjusting it do anyways, ive never done it before thanks
Old Jun 12, 2003 | 02:21 AM
AlphaQup's Avatar
Default Re: (stripes777)
lol you gotta adjust your valves every time you press your car to the limit, such as mimicking 2fast2furious race scenes. regular 60,000 mile interval adjustments should be takin into concideration if you drive your car regularly. Valves let your car breath... not adjusting them causes ristriction and not to mention a whole lotta knocking down the line. So it be a good idea to adjust your valves regularly if you like to drive hard . cheers
Old Jun 12, 2003 | 02:36 AM
stripes777's Avatar
cool, sounds like its an urgent must for my car then. im guessing i can buy the adjustment kit at any autozone or something right?
thanks
Old Jun 12, 2003 | 02:43 AM
AlphaQup's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stripes777 &raquo;</TD></TR><TR><TD CLASS="quote">im guessing i can buy the adjustment kit at any autozone or something right?
thanks</TD></TR></TABLE>
all you really need is a 10mm wrench, a flathead skrewdriver, and feeler gauge. but if you want to buy the tool, i beleave pepboys or autozone carries it.
fwdupree
Jun 1, 2018 12:13 PM
supersize
Jul 26, 2010 11:50 PM
Shift_Fast
Feb 19, 2005 11:24 AM
pgflash
Oct 3, 2004 07:41 AM
laNk_LinK
Mar 3, 2003 03:27 AM
