JDM B16a SI-RII is equivalent with which motor in US?
Old Jun 11, 2003 | 04:41 PM
VWkila's Avatar
Default JDM B16a SI-RII is equivalent with which motor in US?
I bought a JDM B16a sirII motor recently without doing much homework!
Which motor does this motor share it's parts in US? Such as water pump, etc. Also I need to get a wire harness. Which one should I get?
And I DID do "search".
Old Jun 11, 2003 | 04:42 PM
rodrez.'s Avatar
Default Re: JDM B16a SI-RII is equivalent with which motor in US? (VWkila)
Vtec delly, 99Si
Old Jun 11, 2003 | 04:43 PM
Lysawy's Avatar
Default Re: JDM B16a SI-RII is equivalent with which motor in US? (rodrez)
del sol vtec 94+ , 99-2000 si ....
Old Jun 11, 2003 | 04:45 PM
VWkila's Avatar
Default Re: JDM B16a SI-RII is equivalent with which motor in US? (Lysawy)
Thanks a lot guys! So Si coupe wireharness should work as well?
Old Jun 11, 2003 | 10:46 PM
Lysawy's Avatar
no prob
Old Jun 11, 2003 | 11:19 PM
Prevail's Avatar
Wait wait..
What year car are you putting this into?
Also, I don't think the 99-00 SI will work. I used a 92-95 EX harness with my B16A SiR-II swap. I would suggest that, as I KNOW it works. You have to lengthen the IACV wires by about 2" though.
Old Jun 12, 2003 | 02:46 AM
pissedoffsol's Avatar
25 Year Member
the motor is nothing like the 99-00 civic si. it's closest to the del sol vtec, but even still, its not the same.
Old Jun 12, 2003 | 03:20 AM
VWkila's Avatar
Default Re: JDM B16a SI-RII is equivalent with which motor in US? (civicscantdrift)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicscantdrift &raquo;</TD></TR><TR><TD CLASS="quote">Wait wait..
I have '92 CX hatch
Old Jun 12, 2003 | 03:43 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
hp output of a USDM GSR, torque of a B16.
Old Jun 12, 2003 | 05:50 AM
dogpile5's Avatar
25 Year Member
Default Re: JDM B16a SI-RII is equivalent with which motor in US? (Apex i ITR)
technically a JDM b16a sir II has no equivalent in the US. it physically LOOKS like a del sol VTEC motor, obd1, single o2 sensor, IAT on the intake manifold etc... however, it has different internals. regardless which motor you swap the important thing will be which ECU/obd system you plan to run and what car it will be going in.
Old Jun 12, 2003 | 09:51 AM
VWkila's Avatar
Default Re: JDM B16a SI-RII is equivalent with which motor in US? (dogpile5)
So, if I was to replace some internals, it would be difficult?
Also which Helms manual would closely resemble this motor?
Old Jun 12, 2003 | 10:00 AM
4g4me's Avatar
this is retarded....please do not get over technical with this guy.
The engine that your are purchacing is exactly like the 94-97 del sol vtec. The only difference is the pistons have a slightly larger bump, to raise compression to make the acclaimed flywheel numbers, 170/113
note: YOu cannot use the 99-00 civic si harness unless you are putting this into a 99-00 civic.
Best bet would be to use your existing harness and add wires necessary for proper vtec operation.
Your helms manual for the del sol vtec will give you all maintenance and torque specs for that engine.
c'mon people was it really necessary to tell this guy that there is no USDM equivilant? Besides the .2 bump in compression.....?
get over technical with a newbiw to this sport and you will scare him away.. <U>help not hurt please.</U>
Old Jun 12, 2003 | 04:34 PM
Lysawy's Avatar
Default Re: JDM B16a SI-RII is equivalent with which motor in US? (4g4me)
acclaimed flywheel numbers are 170hp/116tq for JDM and usdm gets 160hp/111tq i think these numbers are correct what about whp is there a difference like the flywheel stats or ts BS!...
Old Jun 12, 2003 | 04:43 PM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g4me &raquo;</TD></TR><TR><TD CLASS="quote">this is retarded....please do not get over technical with this guy.
get over technical with a newbiw to this sport and you will scare him away.. <U>help not hurt please.</U> </TD></TR></TABLE>
Exactly, thank you. When you go to the ref with an SiR II motor, the equivalent is a Del Sol Vtec, or a 99Si. No reason to confuse the guy.
Old Jun 12, 2003 | 04:49 PM
ThisLittleSleepeR's Avatar
Old Jun 12, 2003 | 05:38 PM
VWkila's Avatar
Default Re: JDM B16a SI-RII is equivalent with which motor in US? (ThisLittleSleepeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThisLittleSleepeR &raquo;</TD></TR><TR><TD CLASS="quote">
Don't worry. I'm not afraid. Actually, I'm not that new. I just spent all my times in Intregra and not really on Civics, especially JDM ones.
Old Jun 13, 2003 | 08:15 AM
dogpile5's Avatar
25 Year Member
best harness will be a 94-95 del sol vtec, in your 92 civic. those are hard to come by, so a stock 93-95 civic ex coupe harness should do you fine with slight modification (thats what i used) if its not already wired for vtec.
also check on motor mounts shift linkage and axles.
Old Jun 13, 2003 | 08:37 AM
ce's Avatar
ce
Well said
Old Jun 13, 2003 | 08:58 AM
VWkila's Avatar
Default Re: JDM B16a SI-RII is equivalent with which motor in US? (ce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ce &raquo;</TD></TR><TR><TD CLASS="quote">
Well said </TD></TR></TABLE>
DAMNNN!!! This is a tough crowd!!! Even a Danish is bashing me!
Stick with your pastries
Old Jun 13, 2003 | 09:36 AM
dogpile5's Avatar
25 Year Member
no bashing from me...just setting you up with some useful info buddy. good luck on the swap!
Old Jun 13, 2003 | 09:49 AM
VWkila's Avatar
thanks, I appreciate that
B16A2-EM1's Avatar
Does anyone know why the JDM B16 is 170hp and the American one is only 160hp?
Old Jun 13, 2003 | 09:50 AM
VWkila's Avatar
Default Re: JDM B16a SI-RII is equivalent with which motor in US? (B16A2-EM1)
I beleive JDM pistons use P30 pistons, which gives higher compression ratio.
Old Jun 13, 2003 | 09:59 AM
Nextelbuddy's Avatar
yea usually jdm motors have slightly highe compressions by different pistons than the usdm market motors. but hardly noticable u know. IMO id rather have a usdm motor that has papers that i can see has actual miles u know. id rather have piece of mind with lower miles than higher compression by a neglibale amount.
Old Jun 13, 2003 | 10:06 AM
mr2kqql's Avatar
Default Re: JDM B16a SI-RII is equivalent with which motor in US? (nextelbuddy)
I would take a Jdm motor over USDM anyday man, honda is built to beat on it dude, beat on it everytime, anyday no problem what so ever. and you know why usdm have less hp, because japanese like to put shity stuff and outdated product in US martket.
