audio wiring on 99 civic
Old Jun 11, 2003 | 04:40 PM
yee SERIOUS's Avatar
Default audio wiring on 99 civic
does anyone know what each color wire is on a 99 honda civic? i'm pretty sure it's in the helms manuel. i'm hooking up a new deck and i'm changing the plug, so i need to know what each wire on the stock plug is so i can swap it correctly. thanks.
Old Jun 11, 2003 | 04:41 PM
PetroGuyX's Avatar
buy a wiring harness, make your life easier, they color code the aftermarket radio harness and the wiring harness, so it should be fine
Old Jun 11, 2003 | 04:49 PM
Default Re: (PetroGuyX)
i have an aftermarket one for my old one...and i had to buy it too...cause i got the deck from my friend and he's still using his old plug...it was 15 bucks down the drain...i don't feel like using another 15 for it
Old Jun 11, 2003 | 05:36 PM
PetroGuyX's Avatar
how is that down the drain? it's a lot less hassle IMO
Old Jun 11, 2003 | 09:48 PM
how much of a hassle is cutting wirings, striping it, and connecting it with the new harness to plug into the deck? and then put electric tape around it so it doesn't touch the other wires?
anyways...does anyone know? i'm sure it's in the helms manual...but i don't have one.
Old Jun 12, 2003 | 07:46 AM
X0's Avatar
X0
Default Re: (LiTtOGPiMp)
This is the Honda side...
+12v Battery =white/yellow stripe
+12v Ignition =Yellow/Red stripe
Ground =Black
Pwr Antenna =Brown/White Stripe
R. Rear speaker+=Red/yellow stripe
R. Rear speaker- =Brown/White stripe
L. Rear speaker+ =Blue/Yellow stripe
L. Rear speaker- =Gray/White stripe
R. Front speaker+ =Red/Green stripe
R. Front speaker- =Brown/Black stripe
L. Front speaker+ =Blue/Green stripe
L. Front speaker- =Gray/Black stripe
...i think that's all of 'em. PM me if you have a Q.
Old Jun 12, 2003 | 07:54 AM
X0's Avatar
X0
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LiTtOGPiMp &raquo;</TD></TR><TR><TD CLASS="quote">how much of a hassle is cutting wirings, striping it, and connecting it with the new harness to plug into the deck? and then put electric tape around it so it doesn't touch the other wires?
anyways...does anyone know? i'm sure it's in the helms manual...but i don't have one.</TD></TR></TABLE>
It is actually pretty easy to do this. You'll need a good set of strippers/crimpers and some butt connectors. Don't use electro tape! Most of your aftermarket harnesses come stripped, so you may not even need to strip anything, just connect it. Most harnesses come with a wiring diagram as well, so really all you do is match up the colors and crimp. Easy stuff.
Old Jun 12, 2003 | 09:54 AM
CtrlAltDel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LiTtOGPiMp &raquo;</TD></TR><TR><TD CLASS="quote">i have an aftermarket one for my old one...and i had to buy it too...cause i got the deck from my friend and he's still using his old plug...it was 15 bucks down the drain...i don't feel like using another 15 for it</TD></TR></TABLE>
Even with *****'s information, I recommend buying a harness. Before you chop up your wires, look into some how-to's, etc... you could really lose some money if you don't.
Old Jun 12, 2003 | 10:39 AM
X0's Avatar
X0
Default Re: (CtrlAltDel)
I am not promoting, nor condoning, the cutting of the factory harness.
I just gave him what he asked for. An aftermarket adapter harness is the only way to go PERIOD
It'll save you SO much time, and make reinstallation of the factory HU easier...wait no... POSSIBLE, not easier!
Old Jun 12, 2003 | 12:03 PM
vteg's Avatar
New User
Default Re: (BAdMutHA)
And the next owner of your car will not want your head if you leave the factory harness intact. You own a 4 year old car. Spend the 20 bucks and don't f-up the factory harness.
Old Jun 12, 2003 | 05:03 PM
PetroGuyX's Avatar
Default Re: (vteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteg &raquo;</TD></TR><TR><TD CLASS="quote">And the next owner of your car will not want your head if you leave the factory harness intact. You own a 4 year old car. Spend the 20 bucks and don't f-up the factory harness.</TD></TR></TABLE>
see what if you decide to sell the car? and you decide you want your cd player out of it, then you spend about 30-40 bucks for two more harnesses so you can put the stock harness back on
B_Swapped93
Mar 7, 2014 04:54 PM
upgrayedd
Dec 24, 2009 04:57 PM
CivicRider011
Audio / Security / Video
Dec 10, 2006 07:07 PM
sanders711
Oct 7, 2002 09:31 PM
lodown414
Jun 20, 2002 04:04 PM
