would it be difficult to make an H22 intake manifold fit an H23?
Old Jun 11, 2003 | 04:00 PM
Greyout's Avatar
Default would it be difficult to make an H22 intake manifold fit an H23?
anyone ever compared the gaskets to see what doesn't line up?
edit:
reason: I found a cheap sheetmetal drag manifold for an H22 and want to use it on my H23
Old Jun 12, 2003 | 07:56 AM
civilude92's Avatar
the top half and throttle body will bolt on but the h22 manifold won't bolt to the h23 head
Old Jun 12, 2003 | 09:05 AM
HotWheelz's Avatar
Default Re: (civilude92)
ok.. first your wrong.
both intake manifolds have swapable tops, take the h23 top and replace it with the h22 one.. but even that is pointless because i put an h23 tb on a h22 manifold so i guess the other works..
also the mounting pattern on the h23 manifold is COMPLETELy different...
some holes could be drilled and tapped, others well you would have to add material for them to fit...
aka it's hard
totumspiretfoxx
Nov 14, 2016 04:27 PM
IrregularRice
Jun 11, 2008 10:20 PM
Turbo O
Dec 14, 2005 09:24 AM
brickonwheels
Nov 19, 2003 07:39 PM
darylfiend11
Nov 19, 2003 03:29 PM
