Grounding kit diagram
Does anyone have the diagram that shows where the wires go for the grounding kit? I already did a search, i remember someone posting a RHD diagram but the search didnt bring it up. Also how long do i need to make each set of wires and what are the grounding points for an integra? Thx
https://honda-tech.com/zerothread?id=525985 i found part of the diagram here but can someone fill in what has been cut off for me? thx
Here is a list of the earthing points, and each runs to the battery's negative terminal (except for the "upgrade" transmission and block grounds). As for wire length, put the terminal on one end and connect it to the respective grounding point, then run the wire to the negative terminal. This will result in the proper measurement for each wire and will allow you to secure the wires in the manner that you'd like. Finally, 2 gauge wire is excessive for an earthing kit. Eight gauge is the size most frequently used.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thrillhouse »</TD></TR><TR><TD CLASS="quote">Where do you ground the battery to? </TD></TR></TABLE>
The stock location.
The stock location.
BoostedSOHC
90
Oct 26, 2003 11:01 AM
integra-modder
Audio / Security / Video
25
Sep 25, 2003 12:21 PM
