will B16 from 99-00 Si fit in the 4th gen?
Old Jul 19, 2001 | 03:03 PM
nawoj's Avatar
Default will B16 from 99-00 Si fit in the 4th gen?
i know the 4th gens dont have hydro trannys but the 99-00 does. will it still fit?
Old Jul 19, 2001 | 04:02 PM
MugenFormula1's Avatar
Default Re: will B16 from 99-00 Si fit in the 4th gen? (nawoj)
just use the block and buy a cheap a$s cable tranny
Old Jul 19, 2001 | 05:10 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Yeah, you cannot use the distributor, transmission, mounts, ECU, etc.
The bare engine will work, but the problem is that all the sensors have
newer type plugs which are not compatible with the EF Hondas (4th gen)
you will have to either replace the sensors or change the plugs.
That is a good deal for someone who already has a JDM B16 and
wants to put a new B16 with low mileage, that way you can use all the sensors
harness distributor, etc on the new motor.
Good luck
kidxtrue
Nov 1, 2010 07:34 PM
~ZoSo~
Apr 21, 2003 07:30 AM
Chiclets
Feb 7, 2003 02:48 AM
loclowd
Jul 17, 2002 03:33 AM
