Wacko idle
Old Jun 11, 2003 | 08:37 AM
solrunner's Avatar
Default Wacko idle
I have 93 Del sol Si. It's got the 1.6 Vtec motor. I'm having a hell of a time getting it to idle. I have no C.E. lights or anything. It starts and surges from 2k to 3k. then it settles down to about 2100 rpm till it works up and idles at 1500-1700. I have the idle screw all the way closed and I still can't get it to idle. I've adjusted throttle cable swapped out the IAC, brand new IAT. TPS works. Even swapped it for another one I have. Nothing seems to be making a difference. any suggestions????
Old Jun 11, 2003 | 08:40 AM
Ricey McRicerton's Avatar
Default Re: Wacko idle (solrunner)
Vaccum leak buddy..had the same problems with mine when I did my y8 intake manifold swap! Best of luck finding it!
Old Jun 11, 2003 | 08:49 AM
DumpedSi's Avatar
Default Re: Wacko idle (Ricey McRicerton)
i agree, I currently have the same problem from a vuccum leak
Old Jun 11, 2003 | 09:12 AM
solrunner's Avatar
thanks for the heads up. I'll go through it with a fine tooth comb this weekend. I am greatful. both of you.
Ohmega
19
Mar 9, 2016 04:48 AM
james007
Apr 30, 2010 04:26 PM
jdm4drSi
Apr 6, 2007 08:19 AM
hondachris1994
10
Feb 25, 2006 02:37 PM
steve_s
Jan 22, 2003 02:06 AM
