lsvtec w/ Toda C
Old Jun 11, 2003 | 08:20 AM
EF_LSVtec's Avatar
Default lsvtec w/ Toda C
My car was dynoed at 192whp using CTR cams and I'm upgrading to Toda spec C next week. Anyone here have a similar set up and how much more hp's can I expect after tuning.
Old Jun 11, 2003 | 08:51 AM
B16GSR's Avatar
Default Re: lsvtec w/ Toda C (EF_LSVtec)
would like to know as well, cannot decide between the b's and c's
Old Jun 11, 2003 | 09:02 AM
EF_LSVtec's Avatar
Default Re: lsvtec w/ Toda C (B16GSR)
I'm getting the car dynotuned after the install so i'll post the results i guess...just couldnt wait. Although, a friend had his car dynoed with spec C's, similar set up as mine except he had CTR pistons (i have us itr) but he had shitty headers and exhaust, smaller TB (62mm) and posted 204whp/139 torque.
Old Jun 11, 2003 | 09:56 AM
NSX Bob's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16GSR &raquo;</TD></TR><TR><TD CLASS="quote">would like to know as well, cannot decide between the b's and c's</TD></TR></TABLE>
Get C's, I wish I had.
Old Jun 11, 2003 | 11:13 AM
The Crow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_LSVtec &raquo;</TD></TR><TR><TD CLASS="quote">My car was dynoed at 192whp using CTR cams and I'm upgrading to Toda spec C next week. Anyone here have a similar set up and how much more hp's can I expect after tuning.</TD></TR></TABLE>
192whp! What pistons do you have?
Old Jun 11, 2003 | 11:26 AM
EF_LSVtec's Avatar
Default Re: lsvtec w/ Toda C (The Crow)
just us itr pistons, .25 over...Hondata stage 2 made it all happen...pumped at least 30whp from initial dyno.
Old Jun 11, 2003 | 11:29 AM
The Crow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_LSVtec &raquo;</TD></TR><TR><TD CLASS="quote">just us itr pistons, .25 over...Hondata stage 2 made it all happen...pumped at least 30whp from initial dyno.</TD></TR></TABLE>
Nice numbers! Who did your head?
Old Jun 11, 2003 | 11:34 AM
EF_LSVtec's Avatar
redstar racing in Hayward, Ca. ...ported the head and match ported the skunk2intake to the ericks racing TB...my tuner said I could probably gain another 5 whp by replacing my CAI to a bigger diameter one. I will probably do that after I install the new cams on Monday. Todacious spec C cams, hehe
Old Jun 11, 2003 | 11:58 AM
wuhungsixxx's Avatar
New User
i have heard of red star before...is that your tunner...if it is i need to make and appointment so i can pull #s like you ...haha
Old Jun 11, 2003 | 12:07 PM
EF_LSVtec's Avatar
Default Re: lsvtec w/ Toda C (wuhungsixxx)
Give Tito a call (owner), 510-259-0979. He's actually my engine builder and Dynospot in San Jose tunes my Hondata...Freakin $185 per hour for dyno-tuning.
Old Jun 11, 2003 | 12:34 PM
-Racer X-
Guest
Posts: n/a
im goin to dynospot tomm to talk to them about my engine build.
Old Jun 11, 2003 | 12:39 PM
EF_LSVtec's Avatar
Default Re: lsvtec w/ Toda C (-Racer X-)
me too (but not tomorrow)...I have to schedule tuning for next week. what kind of engine are you getting built?
Old Jun 11, 2003 | 12:45 PM
gary201147's Avatar
Default Re: lsvtec w/ Toda C (Type R Bob)
Would Cs be more effective than Bs on a stock 10.6 CR? I'm kinda wondering the same thing but I dont know if I will ever replace my pistons.
&lt;== tryin to keep it stock (as much as possible )
Old Jun 11, 2003 | 12:48 PM
EF_LSVtec's Avatar
Default Re: lsvtec w/ Toda C (gary201147)
i want to find out myself...but my friend who has spec C spins his wheels when his car hits vtec...like a sudden surge of power...
Old Jun 11, 2003 | 12:58 PM
civichopeful's Avatar
I'm building a LS/VTEC motor soon and I am wondering if I would be able to run these cams considering the fact that I am using CTR pistons? I've heard that I might have to worry about contact? Any opinions?
Old Jun 11, 2003 | 02:25 PM
Mr.Integra's Avatar
i would stay away from C's until you have at least a compression of 12:1..
otherwise u might be dissapointed
Old Jun 11, 2003 | 03:15 PM
RaIn's Avatar
Yea also, C's are meant to rev high.... you dont really want to be revving the **** out of your ls/vtec do you?
Old Jun 11, 2003 | 04:20 PM
EF_LSVtec's Avatar
Default Re: lsvtec w/ Toda C (civichopeful)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civichopeful &raquo;</TD></TR><TR><TD CLASS="quote">I'm building a LS/VTEC motor soon and I am wondering if I would be able to run these cams considering the fact that I am using CTR pistons? I've heard that I might have to worry about contact? Any opinions?</TD></TR></TABLE>
Same set up as my friends, CTR pistons, spec C toda cams, no contact, 204 whp at 8500rpm and it's still going up. He just didnt want to break his motor since he just got it broken in but with his set up, it will rev up to 9500 easy.
Old Jun 11, 2003 | 04:50 PM
turbodsmpower's Avatar
Thats good numbers i cant wait to see what mine puts out i have 12.5:1 endyn's but i need a tbody soon. and skunks stg 2 cams im hoping to put down more than 200 also let me know how it goes.
Old Jun 19, 2003 | 10:24 PM
EF_LSVtec's Avatar
Default Re: lsvtec w/ Toda C (turbodsmpower)
New cams (Toda C)were just installed and drove the car for the first time...Dyno-tuning is scheduled for tomorrow afternoon. Idle fluctuates a bit and slight dip in power right when it hits vtec (5700) but pulls stronger than my CTR's all the way to 8500 rpm (i didnt want to rev it higher til its fully tuned). Motor growls louder than usual too especially above 5700 (vtec).Just wanted to share this new found power...Dyno sheet will be posted tomorrow.
Old Jun 19, 2003 | 11:06 PM
3rdGteg's Avatar
can't wait to see the dyno results
Old Jun 19, 2003 | 11:41 PM
KOTSEMOTO's Avatar
Your set up is scary. You should watch the revs.
Were you able to measure piston to valve clearance?
PNOY din ako.
Old Jun 19, 2003 | 11:59 PM
J2turbo21's Avatar
EF_LSVtec what kind of compression you running and do you got the toda valve springs?
Old Jun 20, 2003 | 06:36 AM
EF_LSVtec's Avatar
Default Re: lsvtec w/ Toda C (KOTSEMOTO)
clearance is not an issue to my understanding. My fellow autox'er have similar mods w/CTR pistons and I have us itr (slightly lower dome) and he doesnt have clearance issues. Thanks for looking out though. Salamat!
Old Jun 20, 2003 | 06:39 AM
EF_LSVtec's Avatar
Default Re: lsvtec w/ Toda C (J2turbo21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J2turbo21 &raquo;</TD></TR><TR><TD CLASS="quote">EF_LSVtec what kind of compression you running and do you got the toda valve springs?</TD></TR></TABLE>
Compression? We calculated it between 11.5-11.8. And I do have Toda valvesprings too. (its a must for Toda B and up)
