Code 72: Cyliner misfire...questions..
Old Jul 19, 2001 | 12:57 PM
fowler!'s Avatar
Default Code 72: Cyliner misfire...questions..
My friend has a newly F-Max turboed 97 5-speed 2.2 Cl (basically and Accord motor). He's been driving around for about two weeks without any problems. Today he got a check engine light. We pulled the code and as you can see by the title it was a code 72. It's an otherwise stock motor. He's only boosting 7lbs right now. I'm thinking that it's just the stock spark plugs that are causing it to misfire. Could it be something else? Or does he just have to upgrade to better plugs?
Thanks for the help.
[Modified by fowler, 9:57 PM 7/19/2001]
Old Jul 19, 2001 | 05:03 PM
Hispeed's Avatar
Default Re: Code 72: Cyliner misfire...questions.. (fowler)
tell him to check the #2 plug wire.. This has happened to me at the shittest of times. IE during a drag race. The wire will come loose from the cap and cause the misfire. It makes your car run like absolute ****. I thought I blew my motor the first time it happened. I would personally try using a differnt plug wire (borrowed) to see if that solves the problem if the first remedy doesnt work.
Dan_99accord
Aug 18, 2013 04:22 PM
CRX-CHACE
Feb 27, 2013 04:57 PM
cmyers72
Transmission & Drivetrain
May 17, 2010 02:48 PM
LH-93
Sep 7, 2008 04:28 PM
d16efsedan
23
Mar 30, 2006 05:15 PM
