Old Mar 31, 2015, 04:35 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Specifications and General Overview
Print Wikipost
how to jack up slammed car?
Old Jun 10, 2003 | 07:07 PM
GroundZer0 336's Avatar
Default how to jack up slammed car?
ive been wondering about this, if someone had a kit on their car, and it was slammed, like an inch off the ground....how would they jack the car up to work on it whatnot?
Old Jun 10, 2003 | 07:08 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: how to jack up slammed car? (orgasmobile)
drive up on 2x4's
Old Jun 10, 2003 | 07:11 PM
whoDAT's Avatar
Default Re: how to jack up slammed car? (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">drive up on 2x4's</TD></TR></TABLE>
or bricks.
Old Jun 10, 2003 | 07:13 PM
JDM CTR EK's Avatar
That's what my friends and I do...
Old Jun 10, 2003 | 07:22 PM
GOKOOL Mike's Avatar
Use a hand jack first in the front or back, then use a hydraulic jack.
Old Jun 10, 2003 | 07:34 PM
PSU's Avatar
PSU
formerly DxHatchback
stole the low jack from my moms 93 cobra
creasian's Avatar
Default Re: how to jack up slammed car? (Lance Burkhart)
i just hit a switch and it'll raise off the ground about 9 inches..
Old Jun 10, 2003 | 07:36 PM
GS-Rcivic's Avatar
Default Re: how to jack up slammed car? (DxHatchback)
lift the back end up with a hydrolic jack then put it on a lift (if thats what u want to do) if you just want to take the tires off or something, use a jack that comes stock in cars.
Old Jun 10, 2003 | 08:28 PM
cool i never thought of drivin it on 2x4s. but....if its an inch off the ground....my friends got a kit on his car and hes gonna put his coilovers all the way down before this show next week, and he doesnt know how to jack it back up afterwards, we estimated the fbumper would be about an inch off the ground.
Old Jun 10, 2003 | 08:36 PM
eg94b18's Avatar
pull up on boards or something to raise it up off the ground enough to get the jack under it
Old Jun 10, 2003 | 08:38 PM
JDMC5's Avatar
Default Re: (eg94b18)
Use the stock jack and lift it up high enough till a real heavy duty jack can fit under and take over.
Old Jun 10, 2003 | 08:43 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (Slow-R)
I have 3 pieces of 3/4" plywood, each one prgressively shorter than the one below it. I stack those up and then drive one tire up onto it like a ramp. Then I can get my floor jack underneath the radiator support w/ ease.
Oh and I hope your friend gets those coilovers back to exactly where they are before the show, because any and all changes in ride height will affect alignment settings, including toe-in AND camber.
Old Jun 10, 2003 | 08:45 PM
SMZ GSR's Avatar
Default Re: (PatrickGSR94)
boards work or what i do is use the OEM jack on the side behind the front wheel until front has enough room for my floor jack
Old Jun 10, 2003 | 10:03 PM
JustinL's Avatar
Default Re: how to jack up slammed car? (creasian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by creasian &raquo;</TD></TR><TR><TD CLASS="quote">i just hit a switch and it'll raise off the ground about 9 inches..</TD></TR></TABLE> to that creasian. i just turned my wheel all the way one way and jacked up the body with the factory till i could fit the hydraulic
btw do you have pics of your air setup in the car? i just got 2 compressors and 2 tanks and need ideas to fit that with 2-4 12s for my show car.
Old Jun 10, 2003 | 10:37 PM
Gabe_'s Avatar
Not to hijack this thread... but creasian, your sig is quite possibly the gayest thing I have ever read. LMAO!
Old Jun 10, 2003 | 10:40 PM
tegasaurus's Avatar
Default Re: how to jack up slammed car? (Gabe_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gabe_ &raquo;</TD></TR><TR><TD CLASS="quote">Not to hijack this thread... but creasian, your sig is quite possibly the gayest thing I have ever read. LMAO!</TD></TR></TABLE>
Almost as gay as his title
-ryan
Old Jun 11, 2003 | 12:47 AM
Ham'ed Hatch
Guest
Posts: n/a
same here. but i only got 6 inches of travel on my cans.
Old Jun 11, 2003 | 07:56 AM
hey ham'ed whered you get your cylinders, and how much were they...you put them on yourself? i want some really bad
Old Jun 11, 2003 | 08:13 AM
Ham'ed Hatch
Guest
Posts: n/a
Default Re: (orgasmobile)
i got my **** through Cool Cars (CCE, http://www.coolcars.org) in Lousiville, KY. paid 1100 for a decent f/b kit. i did the entire install myself.
check out street source (link in my sig). wander around in the forums there and you'll learn alot about adj. susp. and where the best place to buy stuff.
good luck, this **** is FUN!
Old Jun 11, 2003 | 11:19 AM
cre18's Avatar
Default Re: (Ham'ed Hatch)
get some car ramps $19.99
Old Jun 11, 2003 | 11:37 AM
kay_animation's Avatar
Whatever you do, make sure you slam the car at the show. If you slam and drive around on that, something in the street, (pothole, steel plate covers, bumps) is going to rip your car apart. Just a quick lookout
Old Jun 11, 2003 | 11:38 AM
sutrusu's Avatar
...definately. the gayest. thing. i have ever. read.
Old Jun 11, 2003 | 11:39 AM
sutrusu's Avatar
Default Re: (cre18)
ramps do not work when you're this low
Old Jun 11, 2003 | 11:54 AM
tha Big EZ's Avatar
Default Re: (sutrusu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sutrusu &raquo;</TD></TR><TR><TD CLASS="quote">ramps do not work when you're this low</TD></TR></TABLE>
it happens playa
Old Jun 11, 2003 | 12:14 PM
projecthybrid04's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow-R &raquo;</TD></TR><TR><TD CLASS="quote">Use the stock jack and lift it up high enough till a real heavy duty jack can fit under and take over. </TD></TR></TABLE>
thats what i do
