My Painted and Polished Wheels (pics)
Old Jun 10, 2003 | 07:03 PM
CircuitFG's Avatar
Default My Painted and Polished Wheels (pics)
the first two were taken outside at aroudn 6:30 or so and it's cloudy so you can't see the shine on the lip too much. . on the second two i took them in my garage, so it stands out more. . but yeah, here is the finished product. . I used rustoleum barbque paint (#7778) for the center pieces, and took the outer piece to mag masters to have the lip repaired and polished. .
Old Jun 10, 2003 | 07:33 PM
t72's Avatar
t72
lookin nice bro
can't wait to see that on your car hehe
Old Jun 10, 2003 | 07:36 PM
Danger's Avatar
Default Re: (t72)
look pretty good . what rims are those ?
CircuitFG's Avatar
Default Re: (JonnyDanger)
Work Fins
Old Jun 10, 2003 | 07:42 PM
silvrintegra's Avatar
Default Re: (CircuitDA9)
Nice job...look REALLY clean. Give pic of them on your car.
Old Jun 10, 2003 | 07:43 PM
CircuitFG's Avatar
Default Re: (silvrintegra)
haha, i haven't put them on yet cuz my clutch went out so i've been outta commission. . i did this in the mean time. I barely got my clutch and flywheel like 2 days ago , and haven't had time to work on the car. Also, i have tires on order. . so when i get the tires, put in the clutch and flywheel, i'll post pics of them on my car. . no problem
Old Jun 10, 2003 | 07:44 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: My Painted and Polished Wheels (CircuitDA9)
did you actually separate and remove the spoked center section from the outer rim? If so w w that sure makes it easy.
Old Jun 10, 2003 | 07:45 PM
CircuitFG's Avatar
Default Re: My Painted and Polished Wheels (PatrickGSR94)
yeah, i took them apart. . made it easier. . but not easy. . 80 bolts i had to take apart. . it was sooo tedious. .
Old Jun 10, 2003 | 08:04 PM
clean's Avatar
New User
how well do you think that paint will hold up? just curious cause i wanted to paint some wheels flat black like that and didnt know what to use. looks reall good i think
Old Jun 10, 2003 | 09:15 PM
CircuitFG's Avatar
Default Re: My Painted and Polished Wheels (clean)
someone else recommended the same paint to me to get the flat black "Spoon" look. Anywho, as long as you do like 2-3 coats it should be ok. The original coat could be used as a primer. Just make sure you either strip the paint like i did (cuz the paint was chipping) or you sand it down really well, so the paint has something to grip to. If you end up needing to strip the paint cuz of paint chipping, i used Aircraft Coat Remover. They sell it at like any kragen or car place. You just let it sit for like 30 seconds and u already see all the paint blistering off. Only one bit of advice. Use gloves when scrubbing the paint off, cuz the spray doesn't hurt. . the bits of paint touchign the skin stings. But yeah, it should hold up well. And if it does chip or whatever, it wont' be hard to paint over. :cP
Old Jun 10, 2003 | 09:16 PM
venom's Avatar
nice OG rims for the DA
Old Jun 10, 2003 | 10:54 PM
NA gs-R 05 C
Guest
Posts: n/a
man, you did a good *** job on those wheels, it came out good.
Old Jun 10, 2003 | 10:56 PM
CircuitFG's Avatar
Default Re: My Painted and Polished Wheels (NA gs-R 05 C)
i forgot to post a before pic, so here is the before pic.
Old Jun 10, 2003 | 10:59 PM
Unsung's Avatar
those wheels look great. I'm a fan of that style wheel.
iHOPEyouCHOKE
Nov 15, 2005 10:27 PM
sohcvtec97
Oct 27, 2005 03:09 PM
DarkBB4
Sep 16, 2005 06:20 PM
LX4CYL
Feb 4, 2004 06:35 PM
pleiades nutz
Mar 11, 2002 11:04 PM
