differences with the 94+LS header and a 99-00 SI header
Old Jun 10, 2003 | 06:42 PM
whitemike1644's Avatar
Default differences with the 94+LS header and a 99-00 SI header
is there any difference if i would use a 4-1 LS header over a 4-1 99-00 SI header on a B16?
Old Jun 10, 2003 | 09:09 PM
CRX Si's Avatar
Default Re: differences with the 94+LS header and a 99-00 SI header (whitemike1644)
i think the 1.8L's are taller... the B16 wont clear the oil pan on a B18
Old Jun 10, 2003 | 10:45 PM
1st-hybrid's Avatar
Default Re: differences with the 94+LS header and a 99-00 SI header (CRX Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Si &raquo;</TD></TR><TR><TD CLASS="quote">i think the 1.8L's are taller... the B16 wont clear the oil pan on a B18</TD></TR></TABLE>
Correct the 1.8 is a bit taller so you'll encounter problems if you try to use the si header.
Edit: I just reread your post, if your trying to use the b18 header on a b16 I don't know if you'll have any problems. I would think since it's longer you should be fine, but I can't say for sure. Do you have the header all ready? Can you test fit it, or another one to see ?
b00sted4dr
Jun 5, 2004 03:20 PM
The OEMobile
Sep 3, 2003 12:33 AM
whitemike1644
Jun 10, 2003 07:36 PM
lsvtec94
Aug 11, 2002 08:30 AM
