Recommended injector size for turbo H22's...?
Old Jun 10, 2003 | 06:40 PM
H22Prelude's Avatar
Default Recommended injector size for turbo H22's...?
What is the recommended injector size for boosted H22's (12-18psi). I'm lookinbg to upgrade. Is 550cc enough?
Old Jun 10, 2003 | 07:04 PM
PrecisionH23a's Avatar
Default Re: Recommended injector size for turbo H22's...? (H22Prelude)
how much power are you looking to make
Old Jun 10, 2003 | 07:24 PM
Anubyss's Avatar
At 18psi, I am thinking 720cc is a better/safer way to go for a H series.
Old Jun 10, 2003 | 07:44 PM
KTeller8's Avatar
Default Re: Recommended injector size for turbo H22's...? (Anubyss)
when is 550 not enough and 720 needed?
i am going to pick some up, but wouldnt 720 be overkill if was only running 7-12 psi now?
Old Jun 10, 2003 | 07:54 PM
H22Prelude's Avatar
I'm looking to put out over 400hp.
Old Jun 10, 2003 | 07:59 PM
Default Re: (H22Prelude)
the infamous 400whp goal....
yes 720s will do.
LJR-LUDE01's Avatar
edit: read firedrake post, I plug in 350 hp at the crank, 4 cylinders and .60 fuel comsumption and it ask for 550cc. since you goin for 400hp defenitely go higher than 550.
Modified by LJR-LUDE01 at 2:30 PM 6/11/2003
Old Jun 10, 2003 | 08:03 PM
Firedrake's Avatar
Default Re: (LJR-LUDE01)
Man, it never ceases to amaze me how much people underestimate their fuel needs!! The calculators at http://www.rceng.com really do work! Put in the numbers and they will let you know what you need.......
I would never go with less than 720's on an H motor. You should already have proper fuel management anyways (Hondata or AEM) so getting big injectors to idle fine should be no problemo. I run 780's and they're great.
Brian
Old Jun 10, 2003 | 11:31 PM
DLB1994's Avatar
Default Re: (Firedrake)
i got 756cc injectors you can never have to much fuel if you have a standalone
Old Jun 11, 2003 | 12:10 AM
H22Prelude's Avatar
I was actually thinking about a VAFC piggyback/hack. And just a Q' out of the blue: Has the 720's greatly affected your mpg?
Old Jun 11, 2003 | 05:28 AM
Boostless97Lude
Guest
Posts: n/a
i've some nice big Precision Turbo 780cc injectors, 500whp mark for me
PnkRokCountryboy
Jun 14, 2005 07:42 AM
00supercivic
Nov 28, 2004 09:03 PM
Sinner
Dec 23, 2003 07:09 PM
Tbone
Mar 11, 2003 10:09 PM
