oil change gone bad
Old Jun 10, 2003 | 06:03 PM
rpm9100's Avatar
Default oil change gone bad
91 DA B18c5 turbocharged/hondata
I just moved to a new city and had to have my oil changed, normaly I do it myself
but all my tools are packed.
For some reason I didn't check the level until the next morning, and I find the level to be about 1/4" above the top dot .
so I start the car and now I am getting a code 20 & 21
my question is can to much oil cause the vtec spool solenoid valve to go bad (code 21)
and what is electrical load detector(code 20)
http://www.hondata.com/techecucodes.html
Old Jun 10, 2003 | 06:30 PM
Philly_NBP_R's Avatar
Default Re: oil change gone bad (rpm9100)
one thing you could try is to unscrew the oil filter (with the engine warm and the car jacked up - obviously). Let some oil drain out, then screw it back in. I know whenever I take my filter out, a bunch of the crap always leaks out all over the place... This would be better than trying to loosen the drain bolt. It' probably no more than 1/2 a quart over, so don't drain too much.
Good luck
oh yeah, don't forget to reset the ecu...
Old Jun 10, 2003 | 06:36 PM
rpm9100's Avatar
thanks man, any input on the error codes?
Old Jun 10, 2003 | 07:55 PM
NSX Bob's Avatar
New User
I'd head back to the place that changed the oil and go crazy right after resolving the problem.
Old Jun 10, 2003 | 08:07 PM
chad's Avatar
Moderator
dude...1/4 inch over the dot.....oh no!!!! no it's not that big of a deal! when road racing i usually over fill my oil so that i'm sure not to starve the engine in the turn.....i think the codes are coincident!
Old Jun 11, 2003 | 06:01 AM
b19coupe's Avatar
1/4" overfull is o.k. Clear the codes and see what happens. Start troubleshooting if the code(s) return.
Old Jun 11, 2003 | 07:21 AM
DarthLuder's Avatar
New User
You got your moneys worth of oil. Now go back and bitch at the foos.
Old Jun 11, 2003 | 07:24 AM
Black Sheep's Avatar
MInes always a bit over the dot, no probs here.
Old Jun 11, 2003 | 10:21 AM
rpm9100's Avatar
Default Re: oil change gone bad (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">1/4" overfull is o.k. Clear the codes and see what happens. Start troubleshooting if the code(s) return.</TD></TR></TABLE>
I am not worried about the oil level, it is the codes i am mainly concerned about.
code 20 electrical load detector????
Old Jun 11, 2003 | 11:28 AM
RagingAngel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rpm9100 &raquo;</TD></TR><TR><TD CLASS="quote">
Don't worry about the codes too much at this point as others have mentioned....
Whoa..more and more edmontonians showing up. Where are you from originally?
Your setup sounds nice...
Old Jun 11, 2003 | 12:41 PM
rpm9100's Avatar
Default Re: oil change gone bad (RagingAngel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel &raquo;</TD></TR><TR><TD CLASS="quote">
Your setup sounds nice...</TD></TR></TABLE>
I lived in Edmonton for 29 years and just recently moved to Ottawa.
I've had my DA for 9 years b18a, b17a, b17a turbo, b18c5, b18c5 turbo...
Why do you say not to worry about the codes?
Old Jun 28, 2003 | 05:12 PM
r7's Avatar
r7
how are the roads in ottawa?
Hondas4All
Oct 22, 2009 12:06 PM
Prelude-TeCh
Jan 20, 2005 02:18 AM
Xxcivic99xX
Aug 12, 2004 10:27 PM
a1320honda
24
Jun 21, 2004 01:17 PM
94GsRacer
Sep 19, 2002 02:43 PM
