antanae broken??
I walked to my car today and noticed that my antanaie was up. I get in the car and turn the radio off. It sounds like its goin down but when i look back, its still up. What is wrong and how much does it cost?? thanks.
try lubing it up good with some WD 40 and give it some slight assistance going up or down....the antenna over time builds up alot of grime on it that will make it stick.
mine and a friend's did the same....you'll have to get something replaced at the dealer which i heard varies between 70-100 bucks.
i decided to spend the 100 on a full S2K assembly so i get good reception and never have to worry about it getting stuck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeff K. »</TD></TR><TR><TD CLASS="quote">sounds expensive. HOw much is the s2k antanae?</TD></TR></TABLE>
depends whether you go with the cheap kit which will total cost you about $45 or going with the whole OEM assembly (and getting better reception) for about $115
i got everythign i needed for my S2k kit to be installed for $36 shipped, the install isn't bad and how good ur signal is depends on where u live and i found that after i installed my cd player the reception was better than OEM radio
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntEGNYC »</TD></TR><TR><TD CLASS="quote">Youll have to order a mast replacement. I read on here that someone paid $50 for their replacement.</TD></TR></TABLE>
I bought my mast for $25 off ebay. Just look up "Integra antenna mast," there's some guy that sells a bunch of them.
yea the kit with the pvc pipe is much cheaper, but i personally didn't like it... such as how you can never unscrew the antenna or the whole kit falls apart and it's weak reception unless in a good area...
From: Slut City aka San Diego, Ca, United State Of King
mine stay up to.. so when i want to put it down .. i push the base of the antanna down a little ..then turn off my radio.. u dont have to the antanna motor ,just get the antanna .its around 45
