Anyone Know where the wire harness is for the Fog Lights on a 1991 3rd gen Prelude
Old Jun 10, 2003 | 03:40 PM
zzzkenji's Avatar
Default Anyone Know where the wire harness is for the Fog Lights on a 1991 3rd gen Prelude
Yah I'm trying to trouble shoot why my fogs have no power but I'm having a hard time following the wireing through the engine compartment and through the fire wall to the relay and switch. I guess if worse comes to worst I'll rewire it all. If anyone has a wireing dia. that would be of great help.
Thanks,
Ken
Old Jun 10, 2003 | 04:11 PM
3gdude's Avatar
Default Re: Anyone Know where the wire harness is for the Fog Lights on a 1991 3rd gen Prelude (zzzkenji)
I'll give it a shot. Forget tracing the wires, problems are usually at the beginning or end of a circuit. Start by removing the fog light switch from the dash. With headlamps on low beam, see if you have ground at the blue wire on back of the switch. If yes, turn fogs on and see if you have ground on the other wire (red/green). When you ground the red/green wire, the fog light relay switches current from fuse #9 (in dash) right to the fog lamps. Do you hear the relay click???....Check these things and post results. Fog light circuits are a little tricky on these cars so diagnostics must be done systematically.......3gdude
Old Jun 11, 2003 | 07:06 AM
zzzkenji's Avatar
Default Re: Anyone Know where the wire harness is for the Fog Lights on a 1991 3rd gen Prelude (3gdude)
Thanks for helping me out. I'll be trying out your recommendatios this weekend and let you know how it goes. Thanks again!
Old Jun 11, 2003 | 03:45 PM
zzzkenji's Avatar
Ok 3gdude. I checked the blue wire for ground and it is grounded and then i checked the red/green for power and it has. When i grounded it i heard the click. Now what please?
Thanks Ken
Old Jun 13, 2003 | 04:00 PM
zzzkenji's Avatar
It's working! I don't know what happened maybe there is a loose conncetion near the switch but it's working now. Thanks for the help.
Ken
hardrock2401
Oct 13, 2013 06:50 PM
JDMarshal
Lighting
Aug 3, 2010 03:44 PM
tomii.dc-5
Honda Civic (2006 - 2015)
14
May 3, 2009 01:02 AM
CWBETB
19
Aug 18, 2008 06:00 PM
caliriptide
Mar 11, 2004 06:25 PM
