question bout ls head?
Old Jun 10, 2003 | 03:36 PM
Ignitecivic's Avatar
Default question bout ls head?
yeah i have question about ls head. im not sure bout this so imma ask u guys. i want to know is it possible to put a 94+ ls head into a 91 ls block. i just want to do a rebuild. do i just put the 94+ ls head right on the 91 block or do i need to use the obdII dist and harness and stuff. let me know guys. thanks
Old Jun 10, 2003 | 03:40 PM
Type Wah's Avatar
94-95 is Obd1, 96-01 is obdII.. someone correct me if i'm wrong..
Havokmkr's Avatar
Default Re: question bout ls head? (Ignitecivic)
All b series heads are compatible w/all b series blocks. Someone correct me if I'm wrong on that. If the engine in a 91 is a b18b then yes.
Old Jun 10, 2003 | 03:41 PM
Havokmkr's Avatar
Default Re: (Type Wah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type Wah &raquo;</TD></TR><TR><TD CLASS="quote">94-95 is Obd1, 96-01 is obdII.. someone correct me if i'm wrong..</TD></TR></TABLE>
Your right, but why does that make a difference.
Old Jun 10, 2003 | 05:22 PM
mr.beeks's Avatar
Default Re: (Havokmkr)
a head is just a head..
the only differences is that the ports have better flow
and emmisions have nothing to do with it
so you dont have to worry about obd
as long as you use the components from previous head ex
intake, distributor and so on..
Old Jun 10, 2003 | 05:49 PM
venom's Avatar
Default Re: (N T R Z R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N T R Z R &raquo;</TD></TR><TR><TD CLASS="quote">a head is just a head..
Old Jun 10, 2003 | 07:34 PM
superls92's Avatar
the heads are compatible you just need to match up distributors. If you have an obd 0 then you need an obd0 distributor. Oh yeah remember that a b20 head will also fit also and I heard they flow better then a b18b.
Old Jun 10, 2003 | 08:03 PM
Default Re: question bout ls head? (superls92)
so it wont matter about the disturbutor rite?. so i can use my obd0 dist and put in an 97+ head. which one is better for a rebuild head. use an ls head or go with the b20 head. do i need to change out the intake manifold and use a diff dist or anything else if i go with the b20 head. thanks for the tips guys.
Old Jun 10, 2003 | 09:26 PM
superls92's Avatar
I would gp with the b20 I have a skunk 2 manifold that I boughtfor my b18 head on my car and the directions say that it fits the b20 and the b18 so I assume that they have the same bolt pattern which means that you can reuse all you stuff from you b18 head but if you are going to port and polish then it really doesn't matter what head that you use.
Old Jun 11, 2003 | 08:56 AM
MAV3RiCK478's Avatar
yes you can do it. keep your OBD0 dizzy, injectors.
go to http://www.g2ic.com and do a search for b18b head swap in the forums section. there is even a image for doing vaccum lines.
vtec killin
Jun 26, 2007 12:06 PM
stackz
Feb 5, 2007 07:45 PM
Mordeki
Sep 22, 2004 08:23 AM
91daLS-V-TEC
Mar 17, 2004 08:04 PM
jdmeg18
Sep 30, 2003 05:20 PM
