temp. questions
Old Jun 10, 2003 | 02:13 PM
95b16hatch's Avatar
Default temp. questions
I have a 95 jdm b16 that runs a temp of over 220 according to my autometer temp gauge. I connected it directly to the temp sensor on the block. Is this reading correctly, if or if not what should I do? did I hook the temp. sensor up correctly?
Old Jun 10, 2003 | 05:27 PM
RCautoworks's Avatar
Default Re: temp. questions (95b16hatch)
You need to mount it inside of a hose, I mounted mine between the eacv hoses. Make sure the hose you pick always has coolant running threw. You might also have to ground the fitting you use.
obuhmyuh
Mar 7, 2010 01:27 PM
kornerk12
Jul 15, 2008 04:59 PM
aasaa666
Apr 26, 2005 07:43 AM
ten_30
Oct 2, 2002 11:08 AM
seanb18c1
Feb 12, 2002 04:55 PM
