Fuel Pressure
As of now i have installed: aem intake, header, cat-back, msd ign. and fpr. Does anyone know what fuel pressure that i should run with my setup?? Stock, with the hose on, it's 40 psi. i'm running right now 47 psi. Any recomendations??
Always adjust fuel pressure with the JOSE OFF. For your setup, I would say 50 - 54 would be ideal at wide open throttle.
EVIL
[Modified by Evil GS-R, 1:03 PM 7/19/2001]
EVIL
When adjusting fuel pressure you must unhook the vacum hose from the regulator and plug the end of it! This will tell you your fuel pressure at wide open throttle! (WOT) I sugest letting the car warm up to cycle before attempting the adjustments for the fact you will get a better reading!! With the mods you have i would suggest setting it between 50-54psi at (WOT)!!!
EVIL
EVIL
Mr.EM1
Jan 6, 2005 11:17 AM
DLOTYPER
May 31, 2003 10:16 PM
