need help with b16
Old Jun 10, 2003 | 09:24 AM
89turbosi's Avatar
Default need help with b16
I just did a swap in my 89 crx SI i put a b16a1 sir in it...im pretty sure i got the wires right it starts up fine but when i give it gas it misses..it idles kinna high too..i tried to set the timing but it dosent help.tried to ajust the idle too and that dosent help the high idle much...what could be the problem??
Old Jun 10, 2003 | 12:21 PM
EL Vap133's Avatar
Default Re: need help with b16 (89turbosi)
You getting any codes?
Old Jun 10, 2003 | 03:51 PM
89turbosi's Avatar
Im gettin the codes 10 and 15...
Old Jun 10, 2003 | 04:05 PM
EL Vap133's Avatar
You can check those codes here: http://www.teirney.net/civic/ECUErrorCodes.htm
Old Jun 10, 2003 | 04:07 PM
89turbosi's Avatar
they are...Intake Air Temperature (IAT Sensor) and... Ignition Output Signal anyway to check those?
Old Jun 10, 2003 | 07:28 PM
89turbosi's Avatar
bump
Fallriverb16
Oct 13, 2015 07:15 AM
slowcrxsi
Mar 28, 2006 12:37 PM
wicca_eagle
10
Jul 20, 2005 12:39 AM
B1692LS
Feb 19, 2005 01:56 PM
wpgcivic
May 19, 2004 06:02 PM
