4-speed to 5-speed on ZC
Old Jun 10, 2003 | 07:46 AM
titan2k2's Avatar
Default 4-speed to 5-speed on ZC
I have a 91 Dx with a dohc ZC swap and a 4-speed manual tranny. What is needed to swap the 4-speed for a 5-speed Si trany? Also if I were to pay for the install how much should I spend?
Old Jun 10, 2003 | 07:55 AM
DJ_SaNdOz's Avatar
Default Re: 4-speed to 5-speed on ZC (titan2k2)
you'll need the tranny, and a new clutch kit (w/ bearings & all), and then you'll need the flywheel resurfaced & you are done.
Old Jun 10, 2003 | 09:19 AM
altoid's Avatar
Default Re: 4-speed to 5-speed on ZC (DJ_SaNdOz)
why do you need to resurface the flywheel? there is no need unless its warped or cracked in such a way that resurfacing will do anything
edit: well i guess im talking about something different...anywho a resurfacing isn't necessary
Old Jun 10, 2003 | 10:30 AM
Aron Parsons's Avatar
Default Re: 4-speed to 5-speed on ZC (altoid)
You should always resurface a flywheel when a new clutch disc is installed.
Old Jun 10, 2003 | 10:34 AM
blah13's Avatar
Default Re: 4-speed to 5-speed on ZC (Aron Parsons)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aron Parsons &raquo;</TD></TR><TR><TD CLASS="quote">You should always resurface a flywheel when a new clutch disc is installed.</TD></TR></TABLE>
Agreed, its always a good precaution and its only $20-30 and your already buying a clutch for at least $100, I'd do it.
Old Jun 10, 2003 | 12:31 PM
durrett syndrome's Avatar
Default Re: 4-speed to 5-speed on ZC (blah13)
5 speed hub assembly
Old Jun 10, 2003 | 01:53 PM
DJ_SaNdOz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blah13 &raquo;</TD></TR><TR><TD CLASS="quote">
Agreed, its always a good precaution and its only $20-30 and your already buying a clutch for at least $100, I'd do it.</TD></TR></TABLE>
that's exactly it- why skimp on $30?
Old Jun 10, 2003 | 03:06 PM
messeduprex's Avatar
Default Re: 4-speed to 5-speed on ZC (durrett syndrome)
just switched my tranny from an hf to si you dont need new hubs or axles the stds will work fine
johnpowellcrx
Oct 5, 2004 09:23 PM
giantdumbass
10
Oct 18, 2003 11:53 AM
Ronin Panda
15
May 11, 2003 05:05 PM
