need help installing Type S cams
Old Jun 9, 2003 | 06:17 PM
d98clturbo's Avatar
Default need help installing Type S cams
i am going to install some type S cams into my car....i need some help.
1. should i grease up the cams before installing them? if so what type of grease or oil
2. what are the torque specs for the bolts that hold everything in place?
3. should i use some type of seal when replacing everything? if so where should i put it
Old Jun 9, 2003 | 08:06 PM
sslude's Avatar
Default Re: need help installing Type S cams (d98clturbo)
get a friend to help. and get a helms manual. and make sure you have a lot of time, so you dont have to hurry through the labor
Old Jun 9, 2003 | 08:25 PM
Redsim's Avatar
Know a link for a helms manual (5th gen) for a good price?
Old Jun 9, 2003 | 09:28 PM
del_parker's Avatar
Default Re: (Redsim)
http://www.helminc.com/
Old Jun 9, 2003 | 10:02 PM
eg:R's Avatar
hi there, you have bought type s cams for your car, how can u tell that it is the type s cams?
Old Jun 10, 2003 | 07:31 AM
NXLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d98clturbo &raquo;</TD></TR><TR><TD CLASS="quote">i am going to install some type S cams into my car....i need some help.
3. should i use some type of seal when replacing everything? if so where should i put it</TD></TR></TABLE>
1. Use Honda assembly lube liberaly
2 and 3 consult helms manual
Old Jun 10, 2003 | 10:32 PM
eg:R's Avatar
how do u know the difference beteew the type s cam and the regular h22 cams? does the type s cams have any marking or #'s written on? planning to buy some
Old Jun 11, 2003 | 06:54 AM
DsITR's Avatar
Default Re: need help installing Type S cams (jacklee)
I have the helms in .pdf format on my comp..If you need I can send it to you via AIM or email.
make sure you do everything correctly, or you will break a cam.
.I.Need.Money.
Mar 21, 2007 02:40 PM
hondaboi187
Jul 22, 2004 10:45 AM
rpm9100
May 1, 2003 04:28 PM
